Einleitung
This guide will show you how to detach the motherboard from the printer, in order to replace or repair it.
Was du brauchst
Remove the two 7.9 mm screws using a Phillips #1 screwdriver.
Remove the blue lever from its slot by pushing it back and twisting clockwise.
Close the scanner compartment and cover.
Flip the printer over so that the bottom of the printer is facing you.
Use the plastic opening tool to remove the corner of the side panel from the plastic pin.
Use the plastic opening tool to loosen the side panel from the bottom of the printer.
Gently pull the 6 ribbon wires out.
Gently pull the 4 molded cable assemblies out.
Unscrew the five silver Phillips screws that secure the motherboard:
Five 3.65mm Phillips #1 screws.
Once all wires and screws have been removed, gently take the motherboard out of the printer.
These wires are soldered onto the bottom of the PCB and must be de-soldered in order to completely detach the motherboard from the printer.
De-solder these eight solder joints on the bottom of the motherboard.
When reinstalling the motherboard back into the printer, solder the highlighted joints (in orange markers in the second photo) back onto the board.
Congratulations on successfully removing the motherboard from the printer! To reassemble the motherboard, follow these instructions in reverse order.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
