Zum Hauptinhalt wechseln
Canon PowerShot A2200 Back Cover Replacement
Was du brauchst
  1. Canon PowerShot A2200 Back Cover Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • First, remove the batteries and memory card.
    • Remove the 5.0 mm black screw with a Phillips #00 screwdriver.
    • Remove the 5.0 mm silver screw with a Phillips #00 screwdriver.
  2. Canon PowerShot A2200 Back Cover Replacement: Schritt 2, Bild 1 von 1
    • Remove the 5.0 mm black screw on the right with a Phillips #00 screwdriver.
  3. Canon PowerShot A2200 Back Cover Replacement: Schritt 3, Bild 1 von 1
    • Remove the 5.0 mm screw on the left with a Phillips #00 screwdriver.
  4. Canon PowerShot A2200 Back Cover Replacement: Schritt 4, Bild 1 von 3 Canon PowerShot A2200 Back Cover Replacement: Schritt 4, Bild 2 von 3 Canon PowerShot A2200 Back Cover Replacement: Schritt 4, Bild 3 von 3
    • Begin taking off the back cover with a plastic opening tool.
    • Begin by wedging the plastic opening tool behind the bottom left corner of the LCD screen as shown.
    • Slide the plastic opening tool to the right, along the mating edge, to pry off the back cover.
    • Continue taking off the back cover along the left side of the camera as seen in the third picture.
  5. Canon PowerShot A2200 Back Cover Replacement: Schritt 5, Bild 1 von 3 Canon PowerShot A2200 Back Cover Replacement: Schritt 5, Bild 2 von 3 Canon PowerShot A2200 Back Cover Replacement: Schritt 5, Bild 3 von 3
    • Use the plastic opening tool to separate the top section of the back cover from the frame.
    • Once there is enough separation between the back cover and the frame, remove the back cover for replacement.
Abschluss
Baylor, Team 4-5, Williams Spring 2015 Mitglied von Baylor, Team 4-5, Williams Spring 2015
BU-WILLIAMS-S15S4G5
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 24
Insgesamt: 1,003
