Zum Hauptinhalt wechseln
Canon PowerShot A2200 Button Assembly Replacement
Was du brauchst
  1. Canon PowerShot A2200 Button Assembly Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • First, remove the batteries and memory card.
    • Remove the 5.0 mm black screw with a Phillips #00 screwdriver.
    • Remove the 5.0 mm silver screw with a Phillips #00 screwdriver.
  2. Canon PowerShot A2200 Button Assembly Replacement: Schritt 2, Bild 1 von 1
    • Remove the 5.0 mm black screw on the right with a Phillips #00 screwdriver.
  3. Canon PowerShot A2200 Button Assembly Replacement: Schritt 3, Bild 1 von 1
    • Remove the 5.0 mm screw on the left with a Phillips #00 screwdriver.
  4. Canon PowerShot A2200 Button Assembly Replacement: Schritt 4, Bild 1 von 3 Canon PowerShot A2200 Button Assembly Replacement: Schritt 4, Bild 2 von 3 Canon PowerShot A2200 Button Assembly Replacement: Schritt 4, Bild 3 von 3
    • Begin taking off the back cover with a plastic opening tool.
    • Begin by wedging the plastic opening tool behind the bottom left corner of the LCD screen as shown.
    • Slide the plastic opening tool to the right, along the mating edge, to pry off the back cover.
    • Continue taking off the back cover along the left side of the camera as seen in the third picture.
  5. Canon PowerShot A2200 Button Assembly Replacement: Schritt 5, Bild 1 von 3 Canon PowerShot A2200 Button Assembly Replacement: Schritt 5, Bild 2 von 3 Canon PowerShot A2200 Button Assembly Replacement: Schritt 5, Bild 3 von 3
    • Use the plastic opening tool to separate the top section of the back cover from the frame.
    • Once there is enough separation between the back cover and the frame, remove the back cover for replacement.
  6. Canon PowerShot A2200 Button Assembly Replacement, Button Assembly: Schritt 6, Bild 1 von 2 Canon PowerShot A2200 Button Assembly Replacement, Button Assembly: Schritt 6, Bild 2 von 2
    • Remove the internal 4.4mm screw with a Phillips 00 screwdriver.
    • Make sure you're removing the screw circled in red, not the screw crossed out in orange.
  7. Canon PowerShot A2200 Button Assembly Replacement: Schritt 7, Bild 1 von 1
    • Gently lift of the buttons for replacement. They should come off without excessive force.
    • If the buttons do not lift off easily, you may have unscrewed the wrong screw. Revert to previous step.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Benjamin Gee
899 Reputation
5 Anleitungen geschrieben
Baylor, Team 4-5, Williams Spring 2015 Mitglied von Baylor, Team 4-5, Williams Spring 2015
BU-WILLIAMS-S15S4G5
4 Mitglieder
11 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 7
Insgesamt: 641
