Einleitung
This guide walks the reader through how to disassemble the Canon PowerShot A2300 in order to replace the display screen. It is necessary to first remove the front and back covers before reaching the screen.
Was du brauchst
Open the A/V Out Digital port cover on the function button side to reveal a screw.
Open the card/battery latch by sliding the cover away from the camera in the direction indicated by the arrow.
Pull the top of the front cover away from the camera by gripping the top of the front cover by the corners where the cover is still attached to the body.
Hold the camera in your hands with both thumbs on the screen with the screen faced up.
Pull the the bottom left corner of the cover up about an inch to the point shown in the picture.
Remove the 2 screws(1.95 mm) by the top right and bottom right of the screen.
Raise the screen by wedging the spudger between the bottom of the screen and the mount hole.
Wedge the flat end of the spudger between the camera and the function buttons plate to push the plate out from under the hooks that attach the left side of the plate.
Raise the bottom of the function button plate with your thumb.
Use one side of the tweezers to raise the black retaining flap that holds the orange ribbon cable to the zero insertion force (ZIF) connector.
With the bottom of the function button plate still raised pull the screen out to the left until the ribbon cable is out from underneath the function button plate.
2 weitere Personen haben diese Anleitung absolviert.
