Zum Hauptinhalt wechseln
Canon PowerShot A460 Front Lens Replacement
Was du brauchst
  1. Canon PowerShot A460 Front Lens Replacement, Battery: Schritt 1, Bild 1 von 1
    • Slide the switch on the battery cover labeled "CARD/BATT. OPEN." to the right.
    • While still holding the switch, pull the cover down, allowing it to release and open.
  2. Canon PowerShot A460 Front Lens Replacement: Schritt 2, Bild 1 von 1
    • Tilt the camera slightly to allow the batteries to fall out.
  3. Canon PowerShot A460 Front Lens Replacement: Schritt 3, Bild 1 von 1
    • Press on and release the memory card to eject it.
  4. Canon PowerShot A460 Front Lens Replacement, Front Casing: Schritt 4, Bild 1 von 1
    • Unscrew the 5mm Phillips #00 screw from the bottom of the camera.
    • Make sure to keep the different size screws organized to make reassembling the camera simpler.
  5. Canon PowerShot A460 Front Lens Replacement: Schritt 5, Bild 1 von 1
    • Unscrew the three 2mm Phillips #00 screws that are located on the bottom of the camera.
  6. Canon PowerShot A460 Front Lens Replacement: Schritt 6, Bild 1 von 1
    • Remove the 4mm Phillips #00 screw that is located on the left side of the camera, if the display screen is facing you.
  7. Canon PowerShot A460 Front Lens Replacement: Schritt 7, Bild 1 von 1
    • Take out the 4mm Phillips #00 screw under the rubber flap on the right end of the camera.
  8. Canon PowerShot A460 Front Lens Replacement: Schritt 8, Bild 1 von 2 Canon PowerShot A460 Front Lens Replacement: Schritt 8, Bild 2 von 2
    • Remove the second battery cover on the bottom of camera.
    • Take the silver battery out of the camera.
  9. Canon PowerShot A460 Front Lens Replacement: Schritt 9, Bild 1 von 3 Canon PowerShot A460 Front Lens Replacement: Schritt 9, Bild 2 von 3 Canon PowerShot A460 Front Lens Replacement: Schritt 9, Bild 3 von 3
    • Remove the 4mm Phillips #00 screw on the inside of the flap that hides the battery and memory card slots.
    • Remove the light grey, plastic piece.
    • Remove the plastic portion of the battery flap cover. The metal piece will remain attached.
  10. Canon PowerShot A460 Front Lens Replacement: Schritt 10, Bild 1 von 3 Canon PowerShot A460 Front Lens Replacement: Schritt 10, Bild 2 von 3 Canon PowerShot A460 Front Lens Replacement: Schritt 10, Bild 3 von 3
    • Slightly pull on each side of the camera. It should loosen up and come apart.
    • If it does not pull apart right away, use a little more force.
    • Do not give up!
  11. Canon PowerShot A460 Front Lens Replacement, Back Casing: Schritt 11, Bild 1 von 1
    • Remove the back case of the camera by pulling from the top.
    • Be careful when pulling off the case. There is a delicate gold ribbon connecting the bottom of the camera to the back case.
  12. Canon PowerShot A460 Front Lens Replacement, LCD Screen: Schritt 12, Bild 1 von 1
    • Remove the 4mm Phillips #00 screw from above the ribbon.
  13. Canon PowerShot A460 Front Lens Replacement: Schritt 13, Bild 1 von 1
    • Gently peel off the blue tape on the top of the LCD screen.
  14. Canon PowerShot A460 Front Lens Replacement: Schritt 14, Bild 1 von 1
    • Remove the 4mm Phillips #00 screw previously concealed by the blue tape.
  15. Canon PowerShot A460 Front Lens Replacement: Schritt 15, Bild 1 von 1
    • Gently lift the LCD screen off of the front casing by pulling up a tab on the side of the camera.
  16. Canon PowerShot A460 Front Lens Replacement: Schritt 16, Bild 1 von 1
    • Using a spudger, lift the grey tabs to allow the ribbon to slide out.
  17. Canon PowerShot A460 Front Lens Replacement: Schritt 17, Bild 1 von 1
    • Since the tabs have been lifted, the ribbon should now slide out out easily.
    • Be careful not to distort the ribbon in any way.
  18. Canon PowerShot A460 Front Lens Replacement, Motherboard: Schritt 18, Bild 1 von 1
    • Remove the 5mm Phillips #00 screw located above the small black piece on the right side of the mother board.
  19. Canon PowerShot A460 Front Lens Replacement: Schritt 19, Bild 1 von 2 Canon PowerShot A460 Front Lens Replacement: Schritt 19, Bild 2 von 2
    • Remove the 4mm Phillips #00 screw at the bottom of the black piece.
    • Detach the black piece that the screws previously held in place.
  20. Canon PowerShot A460 Front Lens Replacement: Schritt 20, Bild 1 von 1
    • Remove the 5mm Phillips #00 screw in the middle of the motherboard.
  21. Canon PowerShot A460 Front Lens Replacement: Schritt 21, Bild 1 von 1
    • Remove the 5mm Phillips #00 screw that holds the metal piece to the bottom of the camera .
  22. Canon PowerShot A460 Front Lens Replacement: Schritt 22, Bild 1 von 1
    • Remove the 5mm Phillips #00 screw that is located on the top of camera.
  23. Canon PowerShot A460 Front Lens Replacement: Schritt 23, Bild 1 von 1
    • Remove the 2mm Phillips #00 screw that is located on the far left of the motherboard.
    • Be careful not to damage the multiple adjacent orange ribbons.
  24. Canon PowerShot A460 Front Lens Replacement: Schritt 24, Bild 1 von 1
    • Remove the 5mm Phillips #00 screw near the bottom left of the motherboard.
  25. Canon PowerShot A460 Front Lens Replacement: Schritt 25, Bild 1 von 2 Canon PowerShot A460 Front Lens Replacement: Schritt 25, Bild 2 von 2
    • Using a spudger, unlock the locking mechanism that holds the lower orange ribbon in place.
    • Once unlocked, slide out the ribbon.
  26. Canon PowerShot A460 Front Lens Replacement: Schritt 26, Bild 1 von 1
    • Using a spudger, unlock the locking mechanism that holds the upper orange ribbon in place.
  27. Canon PowerShot A460 Front Lens Replacement: Schritt 27, Bild 1 von 1
    • All that is required is to unsolder the few remaining wires. Then, the motherboard will be ready to be replaced!
  28. Canon PowerShot A460 Front Lens Replacement, Front Lens: Schritt 28, Bild 1 von 1
    • Remove the six 2mm Phillips #00 screws that are located under the motherboard.
  29. Canon PowerShot A460 Front Lens Replacement: Schritt 29, Bild 1 von 2 Canon PowerShot A460 Front Lens Replacement: Schritt 29, Bild 2 von 2
    • Remove the 4mm Phillips #00 screw that is located under the now disconnected top orange ribbon.
    • The lens piece can now be removed from the camera.
  30. Canon PowerShot A460 Front Lens Replacement: Schritt 30, Bild 1 von 1
    • Remove the 5mm Phillips #00 screw on the back of the lens piece.
  31. Canon PowerShot A460 Front Lens Replacement: Schritt 31, Bild 1 von 1
    • Remove the 2mm Phillips #00 screw on the bottom of the lens piece.
  32. Canon PowerShot A460 Front Lens Replacement: Schritt 32, Bild 1 von 1
    • Remove the two 2mm Phillips #00 screws on the top of the lens piece.
  33. Canon PowerShot A460 Front Lens Replacement: Schritt 33, Bild 1 von 1
    • Gently slide off the black piece surrounding the lens. The lens is now disassembled!
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 19-42, Regan Winter 2013 Mitglied von Cal Poly, Team 19-42, Regan Winter 2013
CPSU-REGAN-W13S19G42
4 Mitglieder
12 Anleitungen geschrieben
1 Kommentar zur Anleitung
please put a big warning note on the step after removing the blue tape from the lens. and the next on is where you lift something on the mother board with a spluger..something like that. well i used a screwdriver and got such a big electrical shock.... scared the crapola out of me. please make a note .... can get electrical shock....
Gaby - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 18
Letzte 30 Tage: 73
Insgesamt: 4,555
