Zum Hauptinhalt wechseln
Canon PowerShot A480 Battery Replacement
Was du brauchst
  1. Canon PowerShot A480 Battery Replacement, Battery: Schritt 1, Bild 1 von 3 Canon PowerShot A480 Battery Replacement, Battery: Schritt 1, Bild 2 von 3 Canon PowerShot A480 Battery Replacement, Battery: Schritt 1, Bild 3 von 3
    • Make sure to fully power off the camera before starting the replacement process.
    • Locate the battery door at the underside of your camera and orient it so that the door points to the right.
    • Gently apply downward pressure to the right edge of the door and slide to the right.
    • Once you hear an audible click, lift up the bay door in the opposite direction till the batteries are fully exposed.
  2. Canon PowerShot A480 Battery Replacement: Schritt 2, Bild 1 von 3 Canon PowerShot A480 Battery Replacement: Schritt 2, Bild 2 von 3 Canon PowerShot A480 Battery Replacement: Schritt 2, Bild 3 von 3
    • Ensure that the contacts for the batteries are free of any corrosion.
    • Gently tip the body of the camera towards your body to slide the batteries out.
    • Slide the batteries out enough to where you are able to grasp both of them for removal.
Abschluss
After obtaining two replacement AA batteries. To reassemble your device, follow these instructions in reverse order.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
UW Tacoma, Team S1-G5, Cardinal Spring 2019 Mitglied von UW Tacoma, Team S1-G5, Cardinal Spring 2019
UWT-CARDINAL-S19S1G5
4 Mitglieder
4 Anleitungen geschrieben
Ein Kommentar
Will the normal AA batteries work?
Viswanath harikumar - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 24
Letzte 30 Tage: 116
Insgesamt: 3,250
