Zum Hauptinhalt wechseln
Canon PowerShot A590 IS Back Cover Replacement
Was du brauchst
  1. Canon PowerShot A590 IS Back Cover Replacement, Batteries: Schritt 1, Bild 1 von 2 Canon PowerShot A590 IS Back Cover Replacement, Batteries: Schritt 1, Bild 2 von 2
    • The battery hatch is on the bottom of the camera.
    • CAUTION: Locate the switch to open the hatch and push gently toward the front of the camera. Too much force can break the hatch.
    • While the switch is pushed forward, pull the cover away from the camera.
  2. Canon PowerShot A590 IS Back Cover Replacement: Schritt 2, Bild 1 von 1
    • This camera requires AA batteries.
    • To remove batteries, simply allow them to fall out of the camera.
    • Use a fingernail to lift the clock battery out of the camera.
  3. Canon PowerShot A590 IS Back Cover Replacement: Schritt 3, Bild 1 von 1
    • When replacing the AA batteries, verify they are oriented correctly by following the (+) and (-) signs on the camera.
  4. Canon PowerShot A590 IS Back Cover Replacement, Back Cover: Schritt 4, Bild 1 von 1
    • Remove the screw located under the rubber flap on the left side of the camera using a Phillips #00 screwdriver.
  5. Canon PowerShot A590 IS Back Cover Replacement: Schritt 5, Bild 1 von 1
    • Remove the two screws located on the other side of the camera using a Phillips #00 screwdriver.
  6. Canon PowerShot A590 IS Back Cover Replacement: Schritt 6, Bild 1 von 1
    • Remove the three screws located at the bottom of the camera using a Phillips #00 screwdriver.
  7. Canon PowerShot A590 IS Back Cover Replacement: Schritt 7, Bild 1 von 1
    • Open the battery cover.
    • Using the iFixit opening tool, push up gently around all edges of the camera.
Abschluss
8 weitere Personen haben diese Anleitung absolviert.
Zach
284 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 9-19, Regan Fall 2010 Mitglied von Cal Poly, Team 9-19, Regan Fall 2010
CPSU-REGAN-F10S9G19
4 Mitglieder
14 Anleitungen geschrieben
Ein Kommentar
i just wanted to by flap to replace over batteries it slides on and off reedalice270@gm.com
Alice Reed - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 9
Letzte 30 Tage: 28
Insgesamt: 8,764
