Einleitung
This guide will instruct the user on how to open the bottom hatch to access the batteries and memory card, and to remove and replace the memory card.
*See battery replacement guide for help opening the hatch.
To eject your memory card, simply press it into the camera gently, and it will spring out.
After it has been released from the camera, just pull it out.
To replace the memory card, make sure it is oriented with the label facing towards the front of the camera, with the contacts going in first, facing the back of the camera.
Push the card into the slot gently until you hear a 'click'. It will then be locked into place in the camera.
3 weitere Nutzer haben diese Anleitung absolviert.
