Zum Hauptinhalt wechseln
Canon PowerShot A610 Broken Control Buttons Repair
Was du brauchst
  1. Canon PowerShot A610 Broken Control Buttons Repair, Batteries: Schritt 1, Bild 1 von 2 Canon PowerShot A610 Broken Control Buttons Repair, Batteries: Schritt 1, Bild 2 von 2
    • Unlock the battery cover, while swinging the cover outward to open it.
  2. Canon PowerShot A610 Broken Control Buttons Repair: Schritt 2, Bild 1 von 1
    • Turn the camera over and allow the batteries to fall out.
    • Close the battery cover.
  3. Canon PowerShot A610 Broken Control Buttons Repair, Camera Housing: Schritt 3, Bild 1 von 3 Canon PowerShot A610 Broken Control Buttons Repair, Camera Housing: Schritt 3, Bild 2 von 3 Canon PowerShot A610 Broken Control Buttons Repair, Camera Housing: Schritt 3, Bild 3 von 3
    • Remove the three 3 mm screws that attach the side panel to the body of the camera.
    • Using your fingernails, pull the side panel outward to remove it.
    • Remove the two remaining 2 mm screws that attach to the frame of the camera.
  4. Canon PowerShot A610 Broken Control Buttons Repair: Schritt 4, Bild 1 von 1
    • Remove the 3 mm screw that sits at the bottom of the camera, near the front side.
    • Remove the 4 mm screw that sits at the bottom of the camera, near the back side.
  5. Canon PowerShot A610 Broken Control Buttons Repair: Schritt 5, Bild 1 von 1
    • Open the battery cover.
    • Remove the 5 mm screw that sits on the top of the battery slot.
    • Remove the three 6 mm screws that sit at the bottom of the battery slot.
  6. Canon PowerShot A610 Broken Control Buttons Repair: Schritt 6, Bild 1 von 2 Canon PowerShot A610 Broken Control Buttons Repair: Schritt 6, Bild 2 von 2
    • Open the digital A/V DC terminal cover.
    • Remove the three 4 mm screws.
    • Detach the digital A/V DC terminal.
    • When you reassemble the camera, leave the topmost screw out until after you put the top casing back.
  7. Canon PowerShot A610 Broken Control Buttons Repair: Schritt 7, Bild 1 von 1
    • Grip the sides of the top cover and gently lift it until it detaches from the camera.
    • Do not completely remove the top cover; an orange ribbon cable still connects it to the camera.
  8. Canon PowerShot A610 Broken Control Buttons Repair: Schritt 8, Bild 1 von 2 Canon PowerShot A610 Broken Control Buttons Repair: Schritt 8, Bild 2 von 2
    • With the camera upside down, pull the side of the front case that is closest to you, in an outward movement.
    • Apply some force, but pull the front case gently to prevent damage.
  9. Canon PowerShot A610 Broken Control Buttons Repair: Schritt 9, Bild 1 von 2 Canon PowerShot A610 Broken Control Buttons Repair: Schritt 9, Bild 2 von 2
    • Open the memory card slot cover.
    • Remove the 3 mm screw that sits near the bottom of the case.
  10. Canon PowerShot A610 Broken Control Buttons Repair: Schritt 10, Bild 1 von 3 Canon PowerShot A610 Broken Control Buttons Repair: Schritt 10, Bild 2 von 3 Canon PowerShot A610 Broken Control Buttons Repair: Schritt 10, Bild 3 von 3
    • Flip the LCD screen all the way open.
    • Grip both sides of top of the back case and gently pull it, in an outward movement, until the case detaches.
  11. Canon PowerShot A610 Broken Control Buttons Repair, Canon PowerShot A610 Broken Control Buttons Repair: Schritt 11, Bild 1 von 2 Canon PowerShot A610 Broken Control Buttons Repair, Canon PowerShot A610 Broken Control Buttons Repair: Schritt 11, Bild 2 von 2
    • Remove the back casing.
    • Flip the casing over and push on the back of the broken button with either your finger or a blunt object until it realigns into its slot.
Abschluss
Cal Poly, Team 11-26, Maness Winter 2011 Mitglied von Cal Poly, Team 11-26, Maness Winter 2011
CPSU-MANESS-W11S11G26
3 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 5,288
