Zum Hauptinhalt wechseln
Canon PowerShot A620 Camera Housing Replacement
Was du brauchst
  1. Canon PowerShot A620 Camera Housing Replacement, Open Battery Door: Schritt 1, Bild 1 von 3 Canon PowerShot A620 Camera Housing Replacement, Open Battery Door: Schritt 1, Bild 2 von 3 Canon PowerShot A620 Camera Housing Replacement, Open Battery Door: Schritt 1, Bild 3 von 3
    • Slide the tab on the battery door while pushing the battery door away from you. The battery door should pop open.
  2. Canon PowerShot A620 Camera Housing Replacement, Insert Batteries: Schritt 2, Bild 1 von 2 Canon PowerShot A620 Camera Housing Replacement, Insert Batteries: Schritt 2, Bild 2 von 2
    • Insert AA batteries according to the diagram printed on the camera.
    • Close the battery door.
  3. Canon PowerShot A620 Camera Housing Replacement, Side Panel: Schritt 3, Bild 1 von 3 Canon PowerShot A620 Camera Housing Replacement, Side Panel: Schritt 3, Bild 2 von 3 Canon PowerShot A620 Camera Housing Replacement, Side Panel: Schritt 3, Bild 3 von 3
    • Unscrew the three Phillips #00 1.6x3mm screws on the side.
    • Lift loose panel from the case.
    • Unscrew the two Phillips #00 1.6x3mm screws that were previously hidden beneath the panel.
  4. Canon PowerShot A620 Camera Housing Replacement, Bottom Panel: Schritt 4, Bild 1 von 1
    • Unscrew the two Phillips #00 1.6x3mm screws on the bottom panel.
  5. Canon PowerShot A620 Camera Housing Replacement, Battery Compartment: Schritt 5, Bild 1 von 1
    • Open the battery door.
    • Unscrew the four Phillips #00 1.6x3mm screws in the battery compartment.
  6. Canon PowerShot A620 Camera Housing Replacement, Terminal Cover: Schritt 6, Bild 1 von 2 Canon PowerShot A620 Camera Housing Replacement, Terminal Cover: Schritt 6, Bild 2 von 2
    • Lift the terminal cover on the side of the camera.
    • Unscrew the three Phillips #00 1.6x3mm screws beneath the terminal cover.
  7. Canon PowerShot A620 Camera Housing Replacement, Top Panel: Schritt 7, Bild 1 von 1
    • Gently pull the top panel to separate it from the case.
    • Although the top panel will now be free from the rest of the case, it will still be attached to the camera by a ribbon cable.
  8. Canon PowerShot A620 Camera Housing Replacement, Front Panel: Schritt 8, Bild 1 von 2 Canon PowerShot A620 Camera Housing Replacement, Front Panel: Schritt 8, Bild 2 von 2
    • Gently pull the front panel to separate it from the camera.
    • The battery terminals are easy to access from this step.
  9. Canon PowerShot A620 Camera Housing Replacement, Terminal Cover: Schritt 9, Bild 1 von 2 Canon PowerShot A620 Camera Housing Replacement, Terminal Cover: Schritt 9, Bild 2 von 2
    • Gently pull the terminal cover to separate it from the camera.
  10. Canon PowerShot A620 Camera Housing Replacement, Memory Card Cover: Schritt 10, Bild 1 von 2 Canon PowerShot A620 Camera Housing Replacement, Memory Card Cover: Schritt 10, Bild 2 von 2
    • Slide the memory card cover down.
    • Unscrew the Phillips #00 1.6x3mm screw beneath the memory card cover.
  11. Canon PowerShot A620 Camera Housing Replacement, Back Panel: Schritt 11, Bild 1 von 2 Canon PowerShot A620 Camera Housing Replacement, Back Panel: Schritt 11, Bild 2 von 2
    • Gently pull the back panel to separate it from the camera.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Jaime Abraham
350 Reputation
3 Anleitungen geschrieben
CSU Fullerton, Team 1-1, Bruce Fall 2014 Mitglied von CSU Fullerton, Team 1-1, Bruce Fall 2014
CSUF-BRUCE-F14S1G1
3 Mitglieder
6 Anleitungen geschrieben
Ein Kommentar
Ottima spiegazione: é tutto facile quando la spiegazione é semplice ed univoca. Ma redigere istruzioni semplici é un'arte che non tutti possiedono.
Paolo Ravera - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 14
Letzte 30 Tage: 36
Insgesamt: 1,790
