Was du brauchst
Unscrew the three Phillips #00 1.6x3mm screws on the side.
Lift loose panel from the case.
Unscrew the two Phillips #00 1.6x3mm screws that were previously hidden beneath the panel.
Open the battery door.
Unscrew the four Phillips #00 1.6x3mm screws in the battery compartment.
Lift the terminal cover on the side of the camera.
Unscrew the three Phillips #00 1.6x3mm screws beneath the terminal cover.
Slide the memory card cover down.
Unscrew the Phillips #00 1.6x3mm screw beneath the memory card cover.
Unscrew the Phillips #00 1.6x3mm screw located on the top panel.
Unscrew the two Phillips #00 1.6x3mm screws that hold in the trigger button.
The trigger button will fall off once the screws have been removed.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
