Was du brauchst
Rotate the screen so that it is perpendicular to the body of the camera
Remove the .2mm screw using a Phillips #00 screwdriver
Rotate screen 180 degrees and remove second .2mm screw
Once the back panel is removed another .2mm screw will be revealed, remove this screw to remove the front panel of the LCD screen
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Locate the ribbon (orange) and using tweezers gently pull back the retaining clip and pull the ribbon out
3 weitere Personen haben diese Anleitung absolviert.
