Einleitung
Use this guide to replace the Canon PowerShot A75's flash unit.
Was du brauchst
Open the memory card slot by sliding it laterally until you hear a click.
Remove the 5.9mm screw in the upper corner of the memory card slot.
Using a pair of tweezers, grab the plug that connects the speaker to the camera and gently pull it out.
Remove the rightmost 4.2mm screw underneath the battery cover, not the center screw.
On the front of the camera, press the button on the lower left of the lens.
Twist the outer lens casing counter-clockwise and slide it out.
Rotate the camera such that the flash unit and capacitor are facing you.
Remove the 3.5mm screw located between the flash unit and the capacitor.
Snap flash unit out of place with your fingers.
Unsolder the five wires connected to the flash unit in order to remove it.
