Zum Hauptinhalt wechseln
Canon PowerShot A75 Speaker Replacement
Was du brauchst
  1. Canon PowerShot A75 Speaker Replacement, Batteries: Schritt 1, Bild 1 von 1
    • Turn the camera over and locate the "BATT OPEN" sliding switch.
  2. Canon PowerShot A75 Speaker Replacement: Schritt 2, Bild 1 von 3 Canon PowerShot A75 Speaker Replacement: Schritt 2, Bild 2 von 3 Canon PowerShot A75 Speaker Replacement: Schritt 2, Bild 3 von 3
    • Slide the switch to the right.
    • The battery cover should slide down and spring open.
  3. Canon PowerShot A75 Speaker Replacement: Schritt 3, Bild 1 von 3 Canon PowerShot A75 Speaker Replacement: Schritt 3, Bild 2 von 3 Canon PowerShot A75 Speaker Replacement: Schritt 3, Bild 3 von 3
    • Remove the 4 AA batteries.
    • Watch for the orientation of the batteries as they slide out.
    • The battery orientation is shown under the battery flap itself and on a sticker next to the battery flap.
  4. Canon PowerShot A75 Speaker Replacement, Speaker: Schritt 4, Bild 1 von 2 Canon PowerShot A75 Speaker Replacement, Speaker: Schritt 4, Bild 2 von 2
    • Open the memory card slot by sliding it laterally until you hear a click
    • Remove the 5.9mm screw in the upper corner of the memory card slot
  5. Canon PowerShot A75 Speaker Replacement: Schritt 5, Bild 1 von 1
    • Remove the two 4.1mm screws at the bottom of the battery flap.
  6. Canon PowerShot A75 Speaker Replacement: Schritt 6, Bild 1 von 2 Canon PowerShot A75 Speaker Replacement: Schritt 6, Bild 2 von 2
    • Lift the shutter button and speaker part from the top of the camera.
    • Do not pull the part too hard because there is a plug connecting the speaker to the camera.
  7. Canon PowerShot A75 Speaker Replacement: Schritt 7, Bild 1 von 3 Canon PowerShot A75 Speaker Replacement: Schritt 7, Bild 2 von 3 Canon PowerShot A75 Speaker Replacement: Schritt 7, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Using a pair of tweezers, grab the plug that connects the speaker to the camera and gently pull it out.
  8. Canon PowerShot A75 Speaker Replacement: Schritt 8, Bild 1 von 1
    • Do not proceed to the next step unless you have previous soldering experience because you can damage the flash unit if you are not careful.
    • Remove the glue and unsolder the speaker from the outer casing. Replace or repair the speaker as necessary.
Abschluss
Austin Fox
1 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 17-30, Amido Spring 2012 Mitglied von Cal Poly, Team 17-30, Amido Spring 2012
CPSU-AMIDO-S12S17G30
5 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 8
Insgesamt: 428
