Einleitung
The flash assembly is a retractable light bulb fixture that displays a quick burst of background light emited from a light bulb.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Remove the three Phillips screws (shown) located at the bottom of the camera.
Open the door to the CompactFlash memory card slot by sliding it towards you and swinging it open.
Remove the memory card if it is still in the camera.
Use the Phillips screwdriver to remove the Phillips screw (shown) underneath the memory card slot door.
Remove the Phillips screw (shown) located inside the top of the memory card compartment.
Open the battery compartment door at the bottom of the camera by sliding the latch to the right and then sliding the door down.
Remove the batteries from the compartment.
Unscrew the three Phillips screws (shown) located inside the battery compartment.
You should now able to remove the top lid of the camera.
The door to the memory card compartment will be freed and should be removable now.
Remove the lower Phillips screw (shown) from the side of the camera.
Open the small rubber door below this screw that covers the connectors.
Open and pivot the LCD screen to its widest open position.
Remove the rear cover by pulling it straight away from the body of the camera.
Now remove the top screw 3.3 mm long on the side of the camera that hold the side panels and the front cover using the #00 screwdriver.
Gently remove the side panel of the camera by pulling it away form the camera.
Unscrew the 2.4 mm long screw that holds on the front panel underneath the side panel using the #00 screwdriver.
Underneath the battery cover there is another 3.8 mm screw in the corner that needs to be removed using the #00 screwdriver.
Unsolder the black and red wires from the back of the circuit board behind the flash.
Use the opening tool to unclip both sides of the black cover on top of the flash
To reassemble your device, follow these instructions in reverse order. Remember to re-solder any wires that were unsoldered.
Ein weiterer Nutzer hat diese Anleitung absolviert.
