Einleitung
This guide will help users remove the back plate and the menu buttons on the Canon PowerShot ELPH 150 IS camera in six simple steps!
Was du brauchst
Locate the ON/Off button on the top of the camera and hold it down until the screen and all lights on the camera go dark.
Locate the back plate of the camera (contains the LCD screen and menu buttons).
To remove the back plate you will need to unscrew the 6 support screws securing it to the camera.
Use a Phillips #00 screwdriver to remove the first 2 screws on the bottom of the camera.
Remove the next 2 screws located behind the AV port using the same Phillips #00 screwdriver.
Use a Phillips #00 screwdriver to remove the final 2 screws from the blue side panel.
Use your hands or a spudger to gently pry the front and back case apart along the seams on the bottom of the camera.
Completely remove the back plate.
