Zum Hauptinhalt wechseln
Canon PowerShot ELPH 300HS Camera Case Replacement
Was du brauchst
    • Before you begin taking apart your device, the first, and MOST IMPORTANT STEPS are to:
    • Turn off your camera.
    • Remove the battery to prevent risk of shock.
  1. Canon PowerShot ELPH 300HS Camera Case Replacement, Remove the Battery: Schritt 2, Bild 1 von 2 Canon PowerShot ELPH 300HS Camera Case Replacement, Remove the Battery: Schritt 2, Bild 2 von 2
    • Turn off your camera by pressing the power button, located on the top-center of the device.
    • Locate the battery door on the bottom right area of the camera case.
    • Place your finger firmly on the black rubber pad on the battery door and slide the door to the right to open it.
    • Locate the orange battery release button beneath the battery door.
    • Slide the battery release button downward to release the battery.
  2. Canon PowerShot ELPH 300HS Camera Case Replacement, Left Side Screws: Schritt 3, Bild 1 von 1
    • Be careful when removing screws, as they are stripped easily.
    • Remove the two screws located on the left side of the camera case, using the Phillips screwdriver #00 (2.0 mm).
  3. Canon PowerShot ELPH 300HS Camera Case Replacement, Bottom Screws: Schritt 4, Bild 1 von 1
    • Remove the two screws on the bottom of the camera located near the battery door (Phillips #00 screwdriver) (4.0 mm).
  4. Canon PowerShot ELPH 300HS Camera Case Replacement, Right Side Screws: Schritt 5, Bild 1 von 1
    • Remove the screw located on the lower right side of the camera case (Phillips #00 screwdriver) (4.0 mm).
    • Remove the HDMI A/V out port cover located on the upper right side of the camera.
    • Remove the screw located just beneath the port cover removed in step 2. (Phillips #00 screwdriver) (2.0 mm).
  5. Canon PowerShot ELPH 300HS Camera Case Replacement: Schritt 6, Bild 1 von 1
    • Remove the back portion of the camera case to reveal the screw located on the top of the case.
    • Remove the screw from the top of camera case, located next to the shutter button (Phillips #00 screwdriver) (1.5 mm).
  6. Canon PowerShot ELPH 300HS Camera Case Replacement, Remove the Case from the Camera: Schritt 7, Bild 1 von 3 Canon PowerShot ELPH 300HS Camera Case Replacement, Remove the Case from the Camera: Schritt 7, Bild 2 von 3 Canon PowerShot ELPH 300HS Camera Case Replacement, Remove the Case from the Camera: Schritt 7, Bild 3 von 3
    • Carefully pry the case apart at the seem, using your fingers.
    • Be careful not to over bend the small metal projections located along the seams. These aid in holding the case together.
    • Be careful not to allow dust or other particles to settle inside of the camera while the case is detached. This can cause functional issues in the future.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Michigan Tech, Team 5-6, Lauer Spring 2014 Mitglied von Michigan Tech, Team 5-6, Lauer Spring 2014
MTU-LAUER-S14S5G6
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 901
