Zum Hauptinhalt wechseln
Canon PowerShot ELPH 310 HS External Panels Replacement
Was du brauchst
  1. Canon PowerShot ELPH 310 HS External Panels Replacement, External Panels: Schritt 1, Bild 1 von 1
    • Use the Phillips #000 screwdriver from the iFixit tool kit to unscrew the two image stabilizer panel’s 2 mm Phillips head screws.
    • Using your hands, remove the image stabilizer panel.
  2. Canon PowerShot ELPH 310 HS External Panels Replacement: Schritt 2, Bild 1 von 2 Canon PowerShot ELPH 310 HS External Panels Replacement: Schritt 2, Bild 2 von 2
    • Unscrew the two 4 mm Phillips head screws from the bottom side of the camera.
  3. Canon PowerShot ELPH 310 HS External Panels Replacement: Schritt 3, Bild 1 von 2 Canon PowerShot ELPH 310 HS External Panels Replacement: Schritt 3, Bild 2 von 2
    • Using your hand, open the battery portal located on the bottom left of the camera. The screw is in the bottom left of the battery portal.
    • Unscrew the hidden 4mm Phillips head screw inside the battery portal.
  4. Canon PowerShot ELPH 310 HS External Panels Replacement: Schritt 4, Bild 1 von 2 Canon PowerShot ELPH 310 HS External Panels Replacement: Schritt 4, Bild 2 von 2
    • Remove the HDMI side panel with your hands.
    • Unscrew the four 4 mm Phillips head screws from the inside of the camera.
  5. Canon PowerShot ELPH 310 HS External Panels Replacement: Schritt 5, Bild 1 von 1
    • The back side of the camera should pop off or be removed by hand.
  6. Canon PowerShot ELPH 310 HS External Panels Replacement: Schritt 6, Bild 1 von 2 Canon PowerShot ELPH 310 HS External Panels Replacement: Schritt 6, Bild 2 von 2
    • Unscrew the one 3 mm Phillips head screw on the top of the camera.
  7. Canon PowerShot ELPH 310 HS External Panels Replacement: Schritt 7, Bild 1 von 1
    • Manually remove the front panel from the camera.
Abschluss
Kadie Aldridge
213 Reputation
2 Anleitungen geschrieben
University of Alabama, Team 1-4, Sydow campbell Fall 2015 Mitglied von University of Alabama, Team 1-4, Sydow campbell Fall 2015
UA-SYDOW CAMPBELL-F15S1G4
4 Mitglieder
4 Anleitungen geschrieben
Ein Kommentar
I have lost the two 4mm screws from the bottom of the camera and would like to buy replacements. Does anyone know the exact size of these screws?
Holland Van Ackeren - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 5
Insgesamt: 427
