Zum Hauptinhalt wechseln
Canon PowerShot ELPH 310 HS LCD Screen Replacement
Was du brauchst
  1. Canon PowerShot ELPH 310 HS LCD Screen Replacement, External Panels: Schritt 1, Bild 1 von 1
    • Use the Phillips #000 screwdriver from the iFixit tool kit to unscrew the two image stabilizer panel’s 2 mm Phillips head screws.
    • Using your hands, remove the image stabilizer panel.
  2. Canon PowerShot ELPH 310 HS LCD Screen Replacement: Schritt 2, Bild 1 von 2 Canon PowerShot ELPH 310 HS LCD Screen Replacement: Schritt 2, Bild 2 von 2
    • Unscrew the two 4 mm Phillips head screws from the bottom side of the camera.
  3. Canon PowerShot ELPH 310 HS LCD Screen Replacement: Schritt 3, Bild 1 von 2 Canon PowerShot ELPH 310 HS LCD Screen Replacement: Schritt 3, Bild 2 von 2
    • Using your hand, open the battery portal located on the bottom left of the camera. The screw is in the bottom left of the battery portal.
    • Unscrew the hidden 4mm Phillips head screw inside the battery portal.
  4. Canon PowerShot ELPH 310 HS LCD Screen Replacement: Schritt 4, Bild 1 von 2 Canon PowerShot ELPH 310 HS LCD Screen Replacement: Schritt 4, Bild 2 von 2
    • Remove the HDMI side panel with your hands.
    • Unscrew the four 4 mm Phillips head screws from the inside of the camera.
  5. Canon PowerShot ELPH 310 HS LCD Screen Replacement: Schritt 5, Bild 1 von 1
    • The back side of the camera should pop off or be removed by hand.
  6. Canon PowerShot ELPH 310 HS LCD Screen Replacement: Schritt 6, Bild 1 von 2 Canon PowerShot ELPH 310 HS LCD Screen Replacement: Schritt 6, Bild 2 von 2
    • Unscrew the one 3 mm Phillips head screw on the top of the camera.
  7. Canon PowerShot ELPH 310 HS LCD Screen Replacement: Schritt 7, Bild 1 von 1
    • Manually remove the front panel from the camera.
  8. Canon PowerShot ELPH 310 HS LCD Screen Replacement, LCD Screen: Schritt 8, Bild 1 von 2 Canon PowerShot ELPH 310 HS LCD Screen Replacement, LCD Screen: Schritt 8, Bild 2 von 2
    • Using your hands, remove the metal piece (surrounding the right side of the screen) from the right side of the camera.
  9. Canon PowerShot ELPH 310 HS LCD Screen Replacement: Schritt 9, Bild 1 von 1
    • Using your hands, lift up the screen.
    • The screen is fragile!
  10. Canon PowerShot ELPH 310 HS LCD Screen Replacement: Schritt 10, Bild 1 von 3 Canon PowerShot ELPH 310 HS LCD Screen Replacement: Schritt 10, Bild 2 von 3 Canon PowerShot ELPH 310 HS LCD Screen Replacement: Schritt 10, Bild 3 von 3
    • The strip tears easily!
    • Manually lift the shutter button plate and remove the white ZIF connector, which is the white clasp underneath.
    • On the front of the camera, using your fingers, undo the orange ribbon from the gray clasp and pull the ribbon through the shutter deck.
Abschluss
Kadie Aldridge
213 Reputation
2 Anleitungen geschrieben
University of Alabama, Team 1-4, Sydow campbell Fall 2015 Mitglied von University of Alabama, Team 1-4, Sydow campbell Fall 2015
UA-SYDOW CAMPBELL-F15S1G4
4 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 14
Insgesamt: 972
