Zum Hauptinhalt wechseln
Canon PowerShot G1 X Battery Replacement
  1. Canon PowerShot G1 X Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Pull the switch on the back of the battery case back towards the open arrow to release a latch.
    • The lid should pop open revealing the battery and a small red switch holding the battery in place.
  2. Canon PowerShot G1 X Battery Replacement: Schritt 2, Bild 1 von 2 Canon PowerShot G1 X Battery Replacement: Schritt 2, Bild 2 von 2
    • To release the battery, gently push the switch off the top of the battery and pull the battery out of the casing.
    • Place the new battery in the casing with the four metal connections (small squares on the bottom of the battery)in the bottom right hand corner of the bottom of the camera. If you look inside the casing you will see where the connections will meet. This will give you more of an idea on the orientation of the battery.
Abschluss
USF Tampa, Team 20-1, Remmell Spring 2017 Mitglied von USF Tampa, Team 20-1, Remmell Spring 2017
USFT-REMMELL-S17S20G1
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 23
Insgesamt: 385
