Einleitung
The device should be turned off and the battery and memory card removed before you start the guide.
Was du brauchst
Remove the three screws on the bottom of the camera using the 00 sized phillips head screw driver.
Open up the HDMI port on the right side of the camera. Then remove the screw in the HDMI port.
Push the button on the bottom right of the camera and then remove the plastic surrounding the lens.
3 weitere Personen haben diese Anleitung absolviert.
