Einleitung
If the LCD screen of your Canon PowerShot G11 LCD is cracked or has stopped working you will need to replace it.
Was du brauchst
Open the LCD screen and turn it so the screen is facing the bottom of the camera, the screw is on the bottom of the LCD screen.
Remove the 3.10mm Philips #00 screw from the bottom end of the LCD screen.
Turn the LCD so that the screen is facing the top of the camera, the screw you need is on the bottom of the LCD screen.
Remove the 3.10mm Philips #00 screw.
Use the plastic opening tool on the indent at the top of the LCD screen to pop off the LCD case.
Remove the 2.22mm Phillips #00 screw that is located next to the indent handle.
On the bottom of the LCD screen carefully turn it so the screen is facing the top of the camera and remove the 2.22mm Phillips #00 screw.
Remove the screen from the base of the LCD.
Do not remove this wire, it is not needed when replacing the screen.
Use the tweezers to lift the small brown plastic snap before you remove the wire.
2 weitere Personen haben diese Anleitung absolviert.
3 Kommentare
Did this. The first time i put it ack together it did not work , Had totake apart and adjust wires okay after put bake together again.
Followed these instructions and the result is excellent. Well done, and thanks very much. Saved me buying another camera!
How do you get a new screen on there?
