Zum Hauptinhalt wechseln
Canon PowerShot G11 Top Cover Replacement
Was du brauchst
  1. Canon PowerShot G11 Top Cover Replacement, Front Cover: Schritt 1, Bild 1 von 2 Canon PowerShot G11 Top Cover Replacement, Front Cover: Schritt 1, Bild 2 von 2
    • Push the button on the bottom right of the camera and then remove the plastic surrounding the lens.
  2. Canon PowerShot G11 Top Cover Replacement: Schritt 2, Bild 1 von 1
    • Use the spudger to pop off front case.
  3. Canon PowerShot G11 Top Cover Replacement: Schritt 3, Bild 1 von 1
    • Pull the loosened cover off and you are finished.
  4. Canon PowerShot G11 Top Cover Replacement, Top Cover: Schritt 4, Bild 1 von 1
    • Once both the front and rear covers are removed, disconnect this ribbon cable by flipping it up and disconnecting it.
  5. Canon PowerShot G11 Top Cover Replacement: Schritt 5, Bild 1 von 1
    • Remove these three screws from the rear side of the camera.
  6. Canon PowerShot G11 Top Cover Replacement: Schritt 6, Bild 1 von 1
    • Remove this screw from the front of the camera.
  7. Canon PowerShot G11 Top Cover Replacement: Schritt 7, Bild 1 von 1
    • Disconnect this cable from the motherboard by sliding it in the direction of the cable (toward the top of the camera).
  8. Canon PowerShot G11 Top Cover Replacement: Schritt 8, Bild 1 von 1
    • Remove the top cover and you are finished.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
USF Tampa, Team 5-6, Brown Winter 2015 Mitglied von USF Tampa, Team 5-6, Brown Winter 2015
USFT-BROWN-W15S5G6
3 Mitglieder
6 Anleitungen geschrieben
Ein Kommentar
In step 5, it is only necessary to take out the 2 SST screws at ~ 10 and 3 o’clock. The grey screw at 7 stays with the body.
In step 7, you need to SLIDE the connector toward the top of the camera toward the dial. The tweezers in the photo are moving LEFT, not toward the viewer as I interpreted it. If you lift it up as if to disconnect a socket (like in step 4) away from the mother board with tweezers, you’ll easily destroy the delicate connector (as I found out).
Dimwit - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 1,610
