Zum Hauptinhalt wechseln
Canon PowerShot G12 Battery Replacement
  1. Canon PowerShot G12 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the camera over with the bottom facing toward you.
    • Place your thumb on the compartment labeled "card/batt open" and slide it outward and up, exposing the battery.
  2. Canon PowerShot G12 Battery Replacement: Schritt 2, Bild 1 von 1
    • Push out the red latch to release the lock.
    • Remove the battery.
    • Note the battery's position in the terminal.
  3. Canon PowerShot G12 Battery Replacement: Schritt 3, Bild 1 von 1
    • To insert a new battery, push the red latch out.
    • Insert the battery into the terminal, ensuring the positive end marked with a red arrow is facing downward.
Abschluss
USF Tampa, Team 1-5, Leahy Winter 2015 Mitglied von USF Tampa, Team 1-5, Leahy Winter 2015
USFT-LEAHY-W15S1G5
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 31
Insgesamt: 1,442
