Zum Hauptinhalt wechseln
Canon PowerShot G3 Speaker Replacement
Was du brauchst
  1. Canon PowerShot G3 Speaker Replacement, Speaker: Schritt 1, Bild 1 von 1
    • Start to remove the screws around the camera: from the front, back, sides, and bottom.
  2. Canon PowerShot G3 Speaker Replacement: Schritt 2, Bild 1 von 1
    • Once the screws are removed, remove the back panel. The panel should be able to be removed by hand.
  3. Canon PowerShot G3 Speaker Replacement: Schritt 3, Bild 1 von 1
    • Next remove the front and right side panels (the left is attached to the front panel).
  4. Canon PowerShot G3 Speaker Replacement: Schritt 4, Bild 1 von 1
    • Finally, remove the top panel as shown.
  5. Canon PowerShot G3 Speaker Replacement: Schritt 5, Bild 1 von 2 Canon PowerShot G3 Speaker Replacement: Schritt 5, Bild 2 von 2
    • The front of the camera should now resemble the picture shown. (Image 1)
    • Remove the capacitor/speaker housing using your finger nail or other thin object to lift it up around the edges. (Image 2)
  6. Canon PowerShot G3 Speaker Replacement: Schritt 6, Bild 1 von 1
    • To remove the circuit ribbon (brown strip) pull it out of the plastic piece it is connected to.
  7. Canon PowerShot G3 Speaker Replacement: Schritt 7, Bild 1 von 1
    • You should now be able to see how the capacitor/speaker housing slides out of the frame.
  8. Canon PowerShot G3 Speaker Replacement: Schritt 8, Bild 1 von 2 Canon PowerShot G3 Speaker Replacement: Schritt 8, Bild 2 von 2
    • Disconnect the speaker wires from the camera, then use a small flat head screw driver to lift the speaker out of its housing.
    • Order a new speaker from the manufacturer or take it to a local electronics store to see if they have one.
Abschluss
Ryan Riales
201 Reputation
2 Anleitungen geschrieben
University of Memphis, Team 3-2, Kim Fall 2015 Mitglied von University of Memphis, Team 3-2, Kim Fall 2015
UM-KIM-F15S3G2
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 9
Insgesamt: 254
