Einleitung
In this guide, we will be showing you how to remove the flash dial in order to replace it.
Was du brauchst
Remove the five 2mm Phillips #000 screws that are under the screen of the camera.
Remove the two 3mm Phillips #000 screws under the AV-out digital flap.
Remove the two 3 mm Phillips #000 screws from the side of the camera.
Remove the two 3 mm Phillips #000 screws on the side of camera with the flash toggle.
Remove the four 4 mm Phillips #000 screws from the plate on the bottom of the camera.
Using the nylon spudger, gently lift the ZIF tab.
Disconnect the ribbon cable that connects the dial to the motherboard.
Remove the dial from the device.
