Zum Hauptinhalt wechseln
Canon PowerShot G7X Dial Replacement
Was du brauchst
  1. Canon PowerShot G7X Dial Replacement, Dial: Schritt 1, Bild 1 von 1
    • Remove the five 2mm Phillips #000 screws that are under the screen of the camera.
  2. Canon PowerShot G7X Dial Replacement: Schritt 2, Bild 1 von 1
    • Remove the two 3mm Phillips #000 screws under the AV-out digital flap.
    • Remove the two 3 mm Phillips #000 screws from the side of the camera.
  3. Canon PowerShot G7X Dial Replacement: Schritt 3, Bild 1 von 1
    • Remove the two 3 mm Phillips #000 screws on the side of camera with the flash toggle.
  4. Canon PowerShot G7X Dial Replacement: Schritt 4, Bild 1 von 1
    • Remove the four 4 mm Phillips #000 screws from the plate on the bottom of the camera.
  5. Canon PowerShot G7X Dial Replacement: Schritt 5, Bild 1 von 1
    • Remove the back plate.
  6. Canon PowerShot G7X Dial Replacement: Schritt 6, Bild 1 von 1
    • Remove the three 3 mm Phillips #000 screws around the dial.
  7. Canon PowerShot G7X Dial Replacement: Schritt 7, Bild 1 von 2 Canon PowerShot G7X Dial Replacement: Schritt 7, Bild 2 von 2
    • Using the nylon spudger, gently lift the ZIF tab.
    • Disconnect the ribbon cable that connects the dial to the motherboard.
    • Remove the dial from the device.
Abschluss
McKenzie Devlin
195 Reputation
1 Anleitung geschrieben
Ein Kommentar
Good guide. If you need to repair the jog dial, check this video for an excellent guide: https://www.youtube.com/watch?v=amuCb5ko...
jnbruin - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 18
Insgesamt: 604
