Zum Hauptinhalt wechseln
Canon PowerShot S100 GPS Board Replacement
Was du brauchst
  1. Canon PowerShot S100 GPS Board Replacement, Outer Case: Schritt 1, Bild 1 von 3 Canon PowerShot S100 GPS Board Replacement, Outer Case: Schritt 1, Bild 2 von 3 Canon PowerShot S100 GPS Board Replacement, Outer Case: Schritt 1, Bild 3 von 3
    • Remove the 2 screws (3.2mm, Phillips #00) found on the bottom side of the camera.
    • Remove the 2 screws (3.2mm, Phillips #00) found on the side of the camera.
    • Remove the 2 screws (3.2mm, Phillips #00) found on the side of the camera where the terminals are.
    • Open the flap revealing the cable inputs and remove the final screw (3.8mm, Phillips #00) found inside.
  2. Canon PowerShot S100 GPS Board Replacement: Schritt 2, Bild 1 von 1
    • Turn the camera so that the LCD screen is facing you.
    • Remove the back panel by pulling it off of the camera.
  3. Canon PowerShot S100 GPS Board Replacement: Schritt 3, Bild 1 von 3 Canon PowerShot S100 GPS Board Replacement: Schritt 3, Bild 2 von 3 Canon PowerShot S100 GPS Board Replacement: Schritt 3, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Turn the camera so that the lens is facing you.
    • Do not pull the front panel off without removing the ribbon cable first.
    • Slowly lift the front panel from the camera.
    • The ribbon cable is connecting the front panel to the camera. Using the tweezers, gently pull the ribbon cable out of its socket.
    • A spudger may also be used to remove the ribbon cable.
    • Remove the rubber guard that rests on top of the lens.
  4. Canon PowerShot S100 GPS Board Replacement, Top Panel: Schritt 4, Bild 1 von 1
    • Turn the camera over on its side so that the terminals are facing you.
    • Remove the screw (3.9mm, Phillips #00) that is connecting the top panel to the metal frame.
  5. Canon PowerShot S100 GPS Board Replacement: Schritt 5, Bild 1 von 2 Canon PowerShot S100 GPS Board Replacement: Schritt 5, Bild 2 von 2
    • Remove the screw (2.9mm, Phillips #00) that is directly above the camera lens.
  6. Canon PowerShot S100 GPS Board Replacement: Schritt 6, Bild 1 von 2 Canon PowerShot S100 GPS Board Replacement: Schritt 6, Bild 2 von 2
    • Using the spudger, remove the center ribbon cable that is connecting the top panel to the motherboard.
    • Gently lift the top panel off the camera.
    • Tweezers may also be used to remove the ribbon cable.
  7. Canon PowerShot S100 GPS Board Replacement, GPS Board: Schritt 7, Bild 1 von 1
    • Turn the camera over so that the camera lens is facing you.
    • Using the spudger, detach the ribbon cable that is connecting the GPS tracker to the motherboard.
  8. Canon PowerShot S100 GPS Board Replacement: Schritt 8, Bild 1 von 2 Canon PowerShot S100 GPS Board Replacement: Schritt 8, Bild 2 von 2
    • Turn the camera over so that the top edge is facing you, and the lens is away from you.
    • Gently lift the folded ribbon cable piece off of the camera body.
    • The folded ribbon cable piece is glued onto the camera, so removing it will require minimal force.
  9. Canon PowerShot S100 GPS Board Replacement: Schritt 9, Bild 1 von 2 Canon PowerShot S100 GPS Board Replacement: Schritt 9, Bild 2 von 2
    • Lift to expose the Phillips #00 screw located beneath it.
    • Unscrew the 2 screws (4.1mm, 1.8mm, both Phillips #00) connecting the GPS tracker to the camera.
    • Remove the GPS tracker by gently lifting it off of the pin that holds it to the top of the camera.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Ricky
968 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 1-4, Leahy Winter 2015 Mitglied von USF Tampa, Team 1-4, Leahy Winter 2015
USFT-LEAHY-W15S1G4
4 Mitglieder
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 13
Insgesamt: 1,167
