Zum Hauptinhalt wechseln
Canon PowerShot S100 Outer Case Replacement
Was du brauchst
  1. Canon PowerShot S100 Outer Case Replacement, Outer Case: Schritt 1, Bild 1 von 3 Canon PowerShot S100 Outer Case Replacement, Outer Case: Schritt 1, Bild 2 von 3 Canon PowerShot S100 Outer Case Replacement, Outer Case: Schritt 1, Bild 3 von 3
    • Remove the 2 screws (3.2mm, Phillips #00) found on the bottom side of the camera.
    • Remove the 2 screws (3.2mm, Phillips #00) found on the side of the camera.
    • Remove the 2 screws (3.2mm, Phillips #00) found on the side of the camera where the terminals are.
    • Open the flap revealing the cable inputs and remove the final screw (3.8mm, Phillips #00) found inside.
  2. Canon PowerShot S100 Outer Case Replacement: Schritt 2, Bild 1 von 1
    • Turn the camera so that the LCD screen is facing you.
    • Remove the back panel by pulling it off of the camera.
  3. Canon PowerShot S100 Outer Case Replacement: Schritt 3, Bild 1 von 3 Canon PowerShot S100 Outer Case Replacement: Schritt 3, Bild 2 von 3 Canon PowerShot S100 Outer Case Replacement: Schritt 3, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Turn the camera so that the lens is facing you.
    • Do not pull the front panel off without removing the ribbon cable first.
    • Slowly lift the front panel from the camera.
    • The ribbon cable is connecting the front panel to the camera. Using the tweezers, gently pull the ribbon cable out of its socket.
    • A spudger may also be used to remove the ribbon cable.
    • Remove the rubber guard that rests on top of the lens.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Ricky
968 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 1-4, Leahy Winter 2015 Mitglied von USF Tampa, Team 1-4, Leahy Winter 2015
USFT-LEAHY-W15S1G4
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 13
Insgesamt: 1,213
