Einleitung
Remove all accessories connected to the camera prior to lens removal out of precaution.
Was du brauchst
Remove the battery by sliding open the cover on the bottom of the camera.
Removing the following 6 Phillips screws will allow access to the inside of the camera:
Remove two screws on the right-side of the camera, near the HDMI port.
Remove two screws on the opposite side of the camera.
Remove the last two screws on the underside of the camera, near the tripod mounting hole.
Remove the Phillips screw near the display holding the bracket in place.
Remove the second Phillips screw in the bottom corner, making it easier to remove the bracket.
Using a plastic spudger, slowly pull out the ribbon using the hole shown in the image. The first of three logic connectors connecting the display to the camera is now removed.
The display should now be partially disconnected from the back side of the camera.
In order to remove the other two connectors, the front of the case must be removed. Slowly pry around the edges using a plastic prying tool to free the case. A lens-ring piece will fall out from the inside of the camera; set this aside.
Remove the two screws that hold the top piece of the plastic case in. One is short, one is long.
With a spudger remove the two rubber pads from the top of the camera to prevent pulling on the flex cable.
Flip up the tab holding down this logic ribbon.
Flip up a second tab holding down this other ribbon; both the cables should be easily removable following this.
Flip up the tab and remove the last ribbon.
The display can now be lifted off the camera and the logic ribbons attached in the front can slide out.
Using a Phillips screwdriver, remove the screws on the small circuit board at the top of the camera.
This will allow you to finish removing the copper panel with either your hands or a prying tool.
Using a Phillips screwdriver, remove the 8 screws attaching the metal panel to the camera.
To remove the flash assembly, disconnect the flex cable connection, then move the flash unit out of the way.
Remove the Phillips screw holding the copper plate in place.
Use a prying tool to lift off the copper plate.
Remove the indicated screw on the front facing side of the lens using a Philips screwdriver.
Next, remove the small attached ribbon by lifting up the clip and gently pulling the ribbon out.
Lift the lens up to reveal the screws underneath.
Remove the 4 Phillips screws connecting the lens to the lens bracket.
9 weitere Nutzer:innen haben diese Anleitung absolviert.
9 Kommentare
There is a step missing, on removing the flash, one side screw and one front, above the lens, otherwise perfect. thank you so much, just as above I had a lens error and ordered a replacement for 14£ from ebay. all works now. thanks.
Is there no other 'fix' without replacing the lens assembly on this particular "Lens error "issue?
@profeduards: try to reseat the flexes from the aperture and IS. You can disassemble the lens to reset the position and/or remove sand but make lots of pictures of the process, and mark (with pencil) a line over the rings (from the front) to know what ring goes where when reassembling. It's possible to reassemble without (as I did, lens was extended so i couldnt) but the process is long, arduous and takes a lot of patience.
Thanks, my Lens was bricked, and with a new Lens kit @15$ from china, it was fixed.
