Zum Hauptinhalt wechseln
Canon PowerShot S230 Display Screen Replacement
Was du brauchst
  1. Canon PowerShot S230 Display Screen Replacement, Display Screen: Schritt 1, Bild 1 von 1
    • Unscrewing the small screws to take off the backing, screws are on the side and there are 4
  2. Canon PowerShot S230 Display Screen Replacement: Schritt 2, Bild 1 von 3 Canon PowerShot S230 Display Screen Replacement: Schritt 2, Bild 2 von 3 Canon PowerShot S230 Display Screen Replacement: Schritt 2, Bild 3 von 3
    • Pry open the backing
    • Look for all screws before moving on
  3. Canon PowerShot S230 Display Screen Replacement: Schritt 3, Bild 1 von 1
    • Remove metal shield from camera
    • It's fine if you just use your hands
  4. Canon PowerShot S230 Display Screen Replacement: Schritt 4, Bild 1 von 1
    • Pry off the the front casing
    • REMOVE ALL SCREWS BEFORE MOVING ON
  5. Canon PowerShot S230 Display Screen Replacement: Schritt 5, Bild 1 von 2 Canon PowerShot S230 Display Screen Replacement: Schritt 5, Bild 2 von 2
    • Remove screws and metal shield at the bottom of the camera
  6. Canon PowerShot S230 Display Screen Replacement: Schritt 6, Bild 1 von 1
    • Remove the screen, also remove any screws that may get in the way, if the screen pops out it’s okay, it’s suppose to do that. Remove the screw at the bottom
  7. Canon PowerShot S230 Display Screen Replacement: Schritt 7, Bild 1 von 3 Canon PowerShot S230 Display Screen Replacement: Schritt 7, Bild 2 von 3 Canon PowerShot S230 Display Screen Replacement: Schritt 7, Bild 3 von 3
    • Remove the highlighted screws to remove the copper facing
    • Now that the screen is replaced, all you need to do is go through the steps in reverse!
Abschluss
Angie
101 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 114
