Einleitung
Use this guide to replace the screen of the Canon PowerShot S230. The guide focuses mainly on the removal of screws and display screen. Fairly simple.
Was du brauchst
Using a Phillips #0 head screwdriver, remove the screws on the outside casing of the camera.
Use a pry tool to open the outer casing of the camera and access the internal components.
Remove the screws on the copper facing from the front part of the camera. Beneath is a connection to the screen. Wiggle this connection to pull it out; it may take some force to do so.
