Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
Use this guide to replace the screen of the Canon PowerShot S230. The guide focuses mainly on the removal of screws and display screen. Fairly simple.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Using a Phillips #0 head screwdriver, remove the screws on the outside casing of the camera.
    • Using a Phillips #0 head screwdriver, remove the screws on the outside casing of the camera.
  2. Use a pry tool to open the outer casing of the camera and access the internal components. Use a pry tool to open the outer casing of the camera and access the internal components. Use a pry tool to open the outer casing of the camera and access the internal components.
    • Use a pry tool to open the outer casing of the camera and access the internal components.
  3. Manta Precision Bit Set
    112 Bits für jede Reparatur.
    Upgrade Your Toolbox
  4. Remove the metal shield and screws from the bottom interior of the camera. Remove the metal shield and screws from the bottom interior of the camera.
    • Remove the metal shield and screws from the bottom interior of the camera.
  5. Use the Phillips head screwdriver to remove the screws securing the screen.
    • Use the Phillips head screwdriver to remove the screws securing the screen.
  6. Remove the screws on the copper facing from the front part of the camera. Beneath is a connection to the screen. Wiggle this connection to pull it out; it may take some force to do so.
    • Remove the screws on the copper facing from the front part of the camera. Beneath is a connection to the screen. Wiggle this connection to pull it out; it may take some force to do so.
Abschluss
Will Appleton
101 Reputation
1 Anleitung geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 129
