Zum Hauptinhalt wechseln
Canon PowerShot S400 Shutter Button Assembly Replacement
Was du brauchst
  1. Canon PowerShot S400 Shutter Button Assembly Replacement, Shutter Button Assembly: Schritt 1, Bild 1 von 2 Canon PowerShot S400 Shutter Button Assembly Replacement, Shutter Button Assembly: Schritt 1, Bild 2 von 2
    • Unless otherwise stated,a #00 philips screwdriver will be used to remove screws.
    • Remove the 4.75mm screw located in the top right corner of the backside of the camera.
    • Remove the four # screws located on the bottom of the camera.
  2. Canon PowerShot S400 Shutter Button Assembly Replacement: Schritt 2, Bild 1 von 3 Canon PowerShot S400 Shutter Button Assembly Replacement: Schritt 2, Bild 2 von 3 Canon PowerShot S400 Shutter Button Assembly Replacement: Schritt 2, Bild 3 von 3
    • Remove the two screws located on the right side of the camera.(the side with the USB adaption plug)
    • Remove the four screws on the left side of the camera.
    • This will release a small metal plate. Remove this plate.
  3. Canon PowerShot S400 Shutter Button Assembly Replacement: Schritt 3, Bild 1 von 3 Canon PowerShot S400 Shutter Button Assembly Replacement: Schritt 3, Bild 2 von 3 Canon PowerShot S400 Shutter Button Assembly Replacement: Schritt 3, Bild 3 von 3
    • There is a small black plastic piece that sits above the lens underneath the camera case. This plastic piece may fall out when you remove the cases; recover the piece and save it.
    • Now separate the front and back camera casings.
  4. Canon PowerShot S400 Shutter Button Assembly Replacement: Schritt 4, Bild 1 von 1
    • Using a spudger, carefully pry the shutter button assembly from the camera.
    • Install the replacement shutter button assembly.
Abschluss
Ross Bryan
359 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 5-19, Amido Winter 2011 Mitglied von Cal Poly, Team 5-19, Amido Winter 2011
CPSU-AMIDO-W11S5G19
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 14
Insgesamt: 2,701
