Einleitung
This guide will show you how to remove and replace the button panel on the top of the camera.
Werkzeuge
Ersatzteile
Kein Ersatzteil erforderlich.
Locate the panel labeled "Batt. Open"
Place your finger on the panel and slide it in the direction of the arrow.
The slot will swing open revealing the battery pack.
Slide this rubber tab out of the way to reveal the bottom screw.
Remove the two 3.7mm screws.
Remove the two 2.3mm outer screws.
Remove the two 3.8mm screws near the strap bracket.
Remove small panel covering mounting bracket.
Remove door covering memory card.
Grasp sides of front cover and carefully pull the front panel off of the camera.
Using your fingernail, gently pry up the clip holding the button panel in place along the side of the camera.
Pry up this small clip with your fingernail.
The button panel will dislodge from the top of the camera allowing you to remove and replace it.
Ein weiterer Nutzer hat diese Anleitung absolviert.
