Einleitung
Use this guide to remove and/or replace the motherboard on the left side of the camera.
  1. Place camera LCD side up and press up on the battery door. Let it swing open until you can see the battery inside.
    • Place camera LCD side up and press up on the battery door.
    • Let it swing open until you can see the battery inside.
  2. Press down on the orange plastic.
    • Press down on the orange plastic.
    • This will gently eject the battery from its compartment.
  3. Holding the edges, slide out the battery. Holding the edges, slide out the battery.
    • Holding the edges, slide out the battery.
  4. Look at the camera from the side with the lanyard and 4 screws.
    • Look at the camera from the side with the lanyard and 4 screws.
      • Remove the two 3.4 mm screws on the metallic colored part.
  5. Remove the 3mm screw on the top left.
    • Remove the 3mm screw on the top left.
      • NOTE: When reassembling, it is helpful to put the top screw back in before placing the front cover back on the camera.
    • Now remove the 5.3mm screw on the bottom.
  6. Place the camera LCD side down.
    • Place the camera LCD side down.
    • Remove the two 5.3mm screws by the battery door.
  7. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  8. Remove the four 3.4mm screws on the bottom of the camera around the tripod mount.
    • Remove the four 3.4mm screws on the bottom of the camera around the tripod mount.
      • Make sure to keep these screws separate from the previous 5.3 mm screws.
  9. Stand the camera back up.
    • Stand the camera back up.
    • Remove the two 3.6mm screws on the side with the A/V Out port.
  10. Lift open the rubber flap covering the A/V Out port.
    • Lift open the rubber flap covering the A/V Out port.
      • Remove the 3.4mm screw in the center.
      • During reassembly, put the A/V out rubber door on before replacing the front panel of the camera
  11. Use a spudger and gently open up the front panel of the camera.
    • Use a spudger and gently open up the front panel of the camera.
      • A thin plastic ribbon will stay connected by a brown piece to front panel of the camera.
  12. There will be a brown plastic piece keeping the thin plastic ribbon in place.
    • There will be a brown plastic piece keeping the thin plastic ribbon in place.
    • Use the spudger to pull out the brown plastic piece attached to the orange plastic.
  13. Use a pair of tweezers and remove the metal piece inside the camera.
    • Use a pair of tweezers and remove the metal piece inside the camera.
  14. Remove the battery door
    • Remove the battery door
      • NOTE: Putting this back on requires aligning the spring on the back of the door with the hole on the camera
  15. Disconnect the black and red cable on the left side of the lens.
    • Disconnect the black and red cable on the left side of the lens.
  16. Disconnect the two orange ribbons on the front of the mother board.
    • Disconnect the two orange ribbons on the front of the mother board.
  17. Pull off the orange ribbon on the upper left of the motherboard.
    • Pull off the orange ribbon on the upper left of the motherboard.
      • This will become available only after removing the ribbon on top.
    • Remove the other two orange ribbons on the middle of the left motherboard.
  18. Remove the 3.3mm screw halfway up the left side of the motherboard just to the left of the lens.
    • Remove the 3.3mm screw halfway up the left side of the motherboard just to the left of the lens.
    • Go under the piece of plastic and remove the 2.6mm screw.
  19. Unplug the top part of the left motherboard. Gently lift the left motherboard up to remove
    • Unplug the top part of the left motherboard.
      • Gently lift the left motherboard up to remove
Abschluss
Jacob
13 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 7-34, Maness Spring 2012 Mitglied von Cal Poly, Team 7-34, Maness Spring 2012
CPSU-MANESS-S12S7G34
5 Mitglieder
6 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 829
