Einleitung
This guide describes how to remove the battery casing for cleaning and to check the connections with the rest of the camera.
Werkzeuge
Ersatzteile
Kein Ersatzteil erforderlich.
Unscrew five Phillips screws using a #0 Phillips screwdriver.
Open the memory card cover by moving the slide switch toward the top end of of the camera.
Remove the memory card from the slot.
Unscrew the four Phillips screws from the side of the casing and one screw from the bottom using a #0 Phillips screwdriver.
Unscrew two Phillips screws above the LCD using a #0 Phillips screwdriver.
Gently separate the top of LCD from the rest of the camera using your thumb.
Place the Spudger in the hole of the electrical ribbon.
Gently pull the ribbon down using the Spudger until it is free from the camera but still connected to the LCD.
Unscrew single Phillips screw with a #0 Phillips screwdriver.
Free the bottom panel and attached ribbon from the rest of the camera.
Turn over the camera.
Lift the clear plastic from the face of the camera, peeling the adhesive just below the zoom lens.
Place the Spudger between the orange ribbon and the black ribbon gate.
Lift the ribbon gate using the Spudger.
Place the Spudger in the corner of the ribbon above the hole.
Remove the ribbon from the ribbon gate by pulling the Spudger away from the gate.
Turn the camera over so you can see the LCD.
Remove single Phillips screw below the LCD using a #0 Phillips screwdriver.
Insert the Spudger into the hole of the ribbon.
Move the Spudger away from the gate to fully remove ribbon.
Lift off the capture button by wiggling it back and forth while pulling upward.
Be careful not to damage the two clips.
Flip open the four ribbon gates using the Spudger.
Gently pull out the ribbon cables from the gates using the Spudger.
Gently lift the logic board.
Place the Spudger so that it is between the logic board, the white ribbon cable, and the rest of the camera.
Remove the white ribbon cable by pulling the Spudger away from the camera, keeping it parallel to the logic board.
Lay the logic board back down so that it is resting on the body of the camera.
Pull the two plugs (white and green) out to the right from the logic board using the tweezers.
Turn the camera over so that the back is facing you.
Unscrew the three Phillips screws using a #0 Phillips screwdriver.
Lift off the Memory Card casing, sliding the ribbon cable through the camera. Keep pulling until the Memory Card and ribbon cable have been removed from the camera.
Note that the ribbon cable is coming from the external front portion of the camera. Make sure that the ribbon cable will not get caught on anything.
Unscrew one Phillips screws from the side and three Phillips screws from the back panel using a #0 Phillips screwdriver.
Firmly push on the back of the zoom lens, removing it from the left portion of the camera.
Lift the zoom lens away from the left portion of the camera so that there are three components connected by a ribbon cables.
The camera should now be able to be set in this orientation without too much stress on the cables.
Locate the ribbon cable going from the battery case to the flash assembly.
Remove the plug from the ribbon cable using the tweezers.
Pick up the remaining battery casing and zoom lens.
Pull off the clear plastic.
The clear plastic is secured by adhesive along the bottom edge and a small hook.
The remaining pieces from left to right are: the battery casing, zoom lens and flash assembly.
Check the battery terminals for any corrosive material or bad connections.
