Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Ersatzteile
Keine Ersatzteile angegeben.
  1. Unscrew five Phillips screws using a #0 Phillips screwdriver. One screw is on upper right corner of the back panel.
    • Unscrew five Phillips screws using a #0 Phillips screwdriver.
    • One screw is on upper right corner of the back panel.
    • The other four screws are on the bottom of the camera.
  2. Open the memory card cover by moving the slide switch toward the top end of of the camera.
    • Open the memory card cover by moving the slide switch toward the top end of of the camera.
    • Remove the memory card from the slot.
  3. Remove the rear cover from the rest of the camera.
    • Remove the rear cover from the rest of the camera.
    • This may require gentle rocking of the case to free it.
  4. Unscrew the four Phillips screws from the side of the casing and one screw from the bottom using a #0 Phillips screwdriver. Unscrew the four Phillips screws from the side of the casing and one screw from the bottom using a #0 Phillips screwdriver.
    • Unscrew the four Phillips screws from the side of the casing and one screw from the bottom using a #0 Phillips screwdriver.
  5. Free the front cover from the rest of the camera.
    • Free the front cover from the rest of the camera.
    • The cover may require gentle rocking to remove.
Ziellinie
Ein weiterer Nutzer hat diese Anleitung absolviert.
Nathan Balcom
81 Reputation
8 Anleitungen geschrieben
Cal Poly, Team 16-28, Maness Winter 2010 Mitglied von Cal Poly, Team 16-28, Maness Winter 2010
CPSU-MANESS-W10S16G28
4 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 26
Insgesamt: 1,514
