Ersatzteile
Kein Ersatzteil erforderlich.
  1. Remove the two screws from the side panel closest to the camera lens. Note: These screws are 2.9 mm long.
    • Remove the two screws from the side panel closest to the camera lens.
    • Note: These screws are 2.9 mm long.
  2. Remove the two screws from the camera bottom panel.
    • Remove the two screws from the camera bottom panel.
  3. Remove the 2 screws from the side panel farthest from the lens.
    • Remove the 2 screws from the side panel farthest from the lens.
  4. Pull the back panel away from the camera body, starting at the end with the function buttons.
    • Pull the back panel away from the camera body, starting at the end with the function buttons.
  5. Remove the small cover panel and attached wrist strap mount.
    • Remove the small cover panel and attached wrist strap mount.
  6. Remove the front cover by gently pulling it away from the camera body.
    • Remove the front cover by gently pulling it away from the camera body.
  7. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  8. Place the front cover, back cover, and wrist strap mount in a safe place until you are ready for reassembly.
    • Place the front cover, back cover, and wrist strap mount in a safe place until you are ready for reassembly.
  9. Remove the 2 screws located at the top of the LCD panel.
    • Remove the 2 screws located at the top of the LCD panel.
    • Note: These screws are 2.4 mm long.
  10. Pull up the metal frame surrounding LCD screen starting at the side of the camera. Pull up the metal frame surrounding LCD screen starting at the side of the camera.
    • Pull up the metal frame surrounding LCD screen starting at the side of the camera.
  11. Push the metal frame away from the metal tab using the spudger, to detach the frame.
    • Push the metal frame away from the metal tab using the spudger, to detach the frame.
    • Rotate the metal frame upwards.
    • Note: The metal framing should be attached by a metal tab towards the bottom of the camera, near the function buttons.
  12. Carefully lift the metal frame from the camera. Remove the black LCD screen, leaving the thin lens pieces in place.
    • Carefully lift the metal frame from the camera.
    • Remove the black LCD screen, leaving the thin lens pieces in place.
    • Note: BE CAREFUL, both components are attached by an orange connector ribbon and cannot be removed yet!
  13. Carefully pull on the orange connector ribbon to disconnect the LCD screen. The LCD screen can be pulled out of the frame before disconnecting its connector ribbon. Note: Tweezers are helpful to disconnect the ribbon
    • Carefully pull on the orange connector ribbon to disconnect the LCD screen.
    • The LCD screen can be pulled out of the frame before disconnecting its connector ribbon.
    • Note: Tweezers are helpful to disconnect the ribbon
  14. Remove the metal frame on the side closest to the flash mechanism. This will  expose the screw securing the flash assembly. Remove the metal frame on the side closest to the flash mechanism. This will  expose the screw securing the flash assembly.
    • Remove the metal frame on the side closest to the flash mechanism. This will expose the screw securing the flash assembly.
  15. Remove the screw securing the flash assembly.
    • Remove the screw securing the flash assembly.
    • Note: The screw is 2.4mm long.
  16. Use the spudger to carefully disconnect the flash assembly ribbon from the black connector lock.
    • Use the spudger to carefully disconnect the flash assembly ribbon from the black connector lock.
  17. Remove the flash assembly. Note: BE CAREFUL, when handling the flash assembly; touching the capacitor (the black cylinder) could shock you
    • Remove the flash assembly.
    • Note: BE CAREFUL, when handling the flash assembly; touching the capacitor (the black cylinder) could shock you
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Phillip Phung
486 Reputation
9 Anleitungen geschrieben
Cal Poly, Team 8-18, Maness Winter 2012 Mitglied von Cal Poly, Team 8-18, Maness Winter 2012
CPSU-MANESS-W12S8G18
4 Mitglieder
10 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 2,413
