Zum Hauptinhalt wechseln
Canon PowerShot SD1000 Lens Replacement
Was du brauchst
  1. Canon PowerShot SD1000 Lens Replacement, Back Panel: Schritt 1, Bild 1 von 2 Canon PowerShot SD1000 Lens Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Remove the two 2.9 mm screws from the side panel closest to the camera lens.
  2. Canon PowerShot SD1000 Lens Replacement: Schritt 2, Bild 1 von 1
    • Remove the two 2.9 mm screws from the camera bottom panel.
  3. Canon PowerShot SD1000 Lens Replacement: Schritt 3, Bild 1 von 1
    • Remove the two 2.9 mm screws from the side panel farthest from the lens.
  4. Canon PowerShot SD1000 Lens Replacement: Schritt 4, Bild 1 von 1
    • Pull the back panel away from the camera body, starting at the end with the function buttons.
  5. Canon PowerShot SD1000 Lens Replacement: Schritt 5, Bild 1 von 1
    • Remove the small cover panel and the attached wrist strap mount.
  6. Canon PowerShot SD1000 Lens Replacement, Front Case: Schritt 6, Bild 1 von 1
    • Remove the front cover by gently pulling it away from the camera body.
  7. Canon PowerShot SD1000 Lens Replacement: Schritt 7, Bild 1 von 1
    • Place the front cover, back cover, and wrist strap mount in a safe place until you are ready for reassembly.
  8. Canon PowerShot SD1000 Lens Replacement, LCD Screen: Schritt 8, Bild 1 von 1
    • Remove the two 2.4 mm screws located at the top of the LCD panel.
  9. Canon PowerShot SD1000 Lens Replacement: Schritt 9, Bild 1 von 2 Canon PowerShot SD1000 Lens Replacement: Schritt 9, Bild 2 von 2
    • Pull up the metal frame surrounding the LCD screen starting at the side of the camera.
  10. Canon PowerShot SD1000 Lens Replacement: Schritt 10, Bild 1 von 1
    • Push the metal frame away from the metal tab using the spudger to detach the frame.
    • Rotate the metal frame upwards.
    • The metal framing should be attached by a metal tab towards the bottom of the camera, near the function buttons.
  11. Canon PowerShot SD1000 Lens Replacement: Schritt 11, Bild 1 von 2 Canon PowerShot SD1000 Lens Replacement: Schritt 11, Bild 2 von 2
    • Carefully lift the metal frame from the camera.
    • Remove the black LCD screen, leaving the thin lens pieces in place.
    • BE CAREFUL; both components are attached by an orange connector ribbon and cannot be removed yet.
  12. Canon PowerShot SD1000 Lens Replacement: Schritt 12, Bild 1 von 3 Canon PowerShot SD1000 Lens Replacement: Schritt 12, Bild 2 von 3 Canon PowerShot SD1000 Lens Replacement: Schritt 12, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Carefully pull on the orange connector ribbon to disconnect the LCD screen.
    • The LCD screen can be pulled out of the frame before disconnecting its connector ribbon.
    • Tweezers are helpful to disconnect the ribbon.
  13. Canon PowerShot SD1000 Lens Replacement, Flash Unit: Schritt 13, Bild 1 von 2 Canon PowerShot SD1000 Lens Replacement, Flash Unit: Schritt 13, Bild 2 von 2
    • Slide the metal frame off of the camera on the side that is closest to the flash mechanism.
  14. Canon PowerShot SD1000 Lens Replacement: Schritt 14, Bild 1 von 1
    • Use a Phillips #00 screwdriver to remove the 2.4 mm screw that secures the flash assembly.
  15. Canon PowerShot SD1000 Lens Replacement: Schritt 15, Bild 1 von 1
    • Use the spudger to gently and carefully disconnect the flash assembly ribbon from the black connector lock.
  16. Canon PowerShot SD1000 Lens Replacement: Schritt 16, Bild 1 von 2 Canon PowerShot SD1000 Lens Replacement: Schritt 16, Bild 2 von 2
    • Pull the flash assembly forward out of the camera to remove it.
    • BE CAREFUL when handling the flash assembly. Touching the capacitor (the black cylinder attached to the flash assembly) could shock you.
  17. Canon PowerShot SD1000 Lens Replacement, Lens: Schritt 17, Bild 1 von 1
    • Remove the 2.90mm screw from the lens, near the motherboard.
  18. Canon PowerShot SD1000 Lens Replacement: Schritt 18, Bild 1 von 2 Canon PowerShot SD1000 Lens Replacement: Schritt 18, Bild 2 von 2
    • Using the spudger remove the shutter button by prying the small tab on the front side of the camera.
  19. Canon PowerShot SD1000 Lens Replacement: Schritt 19, Bild 1 von 2 Canon PowerShot SD1000 Lens Replacement: Schritt 19, Bild 2 von 2
    • With a spudger disconnect the orange connector ribbon as shown.
    • Disconnect the orange connector ribbon that is located under the now removed shutter button.
  20. Canon PowerShot SD1000 Lens Replacement: Schritt 20, Bild 1 von 1
    • Remove the two 2.90 mm screws from the motherboard.
  21. Canon PowerShot SD1000 Lens Replacement: Schritt 21, Bild 1 von 1
    • With Tweezers detach the bottom orange ribbon.
  22. Canon PowerShot SD1000 Lens Replacement: Schritt 22, Bild 1 von 1
    • Remove the screws shown. Start with the outside 6 (3-2.90mm & 3-2.40mm) screws on the metal frame. Then remove the 6 (2.40mm) screws on the back of the lens piece
  23. Canon PowerShot SD1000 Lens Replacement: Schritt 23, Bild 1 von 1
    • With spudger gently remove the Viewfinder Window that is directly above the lens.
  24. Canon PowerShot SD1000 Lens Replacement: Schritt 24, Bild 1 von 3 Canon PowerShot SD1000 Lens Replacement: Schritt 24, Bild 2 von 3 Canon PowerShot SD1000 Lens Replacement: Schritt 24, Bild 3 von 3
    • Detach the mother board with lens from body of camera.
    • Carefully remove the lens from the motherboard. Use tweezers to remove any of the 4 connecting ribbons from the lens.
    • Your lens has been removed from the motherboard and bottom framing.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
Phillip Phung
651 Reputation
9 Anleitungen geschrieben
Cal Poly, Team 8-18, Maness Winter 2012 Mitglied von Cal Poly, Team 8-18, Maness Winter 2012
CPSU-MANESS-W12S8G18
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 10
Letzte 30 Tage: 40
Insgesamt: 5,121
