Zum Hauptinhalt wechseln
Canon PowerShot SD1100 IS Function Buttons Replacement
Was du brauchst
  1. Canon PowerShot SD1100 IS Function Buttons Replacement, Front and Rear Cover: Schritt 1, Bild 1 von 2 Canon PowerShot SD1100 IS Function Buttons Replacement, Front and Rear Cover: Schritt 1, Bild 2 von 2
    • Remove wrist strap and battery.
  2. Canon PowerShot SD1100 IS Function Buttons Replacement: Schritt 2, Bild 1 von 3 Canon PowerShot SD1100 IS Function Buttons Replacement: Schritt 2, Bild 2 von 3 Canon PowerShot SD1100 IS Function Buttons Replacement: Schritt 2, Bild 3 von 3
    • Remove 2 screws from each side of the camera (4 total, 0.102 in).
    • Remove 2 screws from the bottom on the camera (0.138 in).
    • Do not mix the 4 side screws with the 2 bottoms ones; they are different sizes.
  3. Canon PowerShot SD1100 IS Function Buttons Replacement: Schritt 3, Bild 1 von 3 Canon PowerShot SD1100 IS Function Buttons Replacement: Schritt 3, Bild 2 von 3 Canon PowerShot SD1100 IS Function Buttons Replacement: Schritt 3, Bild 3 von 3
    • Gently pull off the front cover.
    • The plate on the side should come off.
    • Gently pull off the back cover.
  4. Canon PowerShot SD1100 IS Function Buttons Replacement: Schritt 4, Bild 1 von 1
    • The cases should now be removed.
  5. Canon PowerShot SD1100 IS Function Buttons Replacement, Top Button Assembly: Schritt 5, Bild 1 von 1
    • Use the spudger to disconnect the black tab.
  6. Canon PowerShot SD1100 IS Function Buttons Replacement: Schritt 6, Bild 1 von 1
    • Gently pull off the shutter button assembly.
  7. Canon PowerShot SD1100 IS Function Buttons Replacement: Schritt 7, Bild 1 von 1
    • Use the tweezers to disconnect the microphone cable.
  8. Canon PowerShot SD1100 IS Function Buttons Replacement: Schritt 8, Bild 1 von 1
    • The shutter button assembly should now be removed.
  9. Canon PowerShot SD1100 IS Function Buttons Replacement, Function Buttons: Schritt 9, Bild 1 von 1
    • With the spudger, flip up the black tab on the main ribbon.
  10. Canon PowerShot SD1100 IS Function Buttons Replacement: Schritt 10, Bild 1 von 2 Canon PowerShot SD1100 IS Function Buttons Replacement: Schritt 10, Bild 2 von 2
    • Gently pull straight out on the ribbon to disconnect it from the logic board.
  11. Canon PowerShot SD1100 IS Function Buttons Replacement: Schritt 11, Bild 1 von 1
    • By hand, gently unfold the function button board and lift it off the frame.
  12. Canon PowerShot SD1100 IS Function Buttons Replacement: Schritt 12, Bild 1 von 1
    • Congratulations! The function button board can now be replaced.
Abschluss
Wyatt Chan
235 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 3-32, Regan Winter 2011 Mitglied von Cal Poly, Team 3-32, Regan Winter 2011
CPSU-REGAN-W11S3G32
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 1,960
