Zum Hauptinhalt wechseln
Canon PowerShot SD1200 IS Motherboard
Was du brauchst
  1. Canon PowerShot SD1200 IS Motherboard, Front and Rear Covers: Schritt 1, Bild 1 von 1
    • Remove the battery.
  2. Canon PowerShot SD1200 IS Motherboard: Schritt 2, Bild 1 von 3 Canon PowerShot SD1200 IS Motherboard: Schritt 2, Bild 2 von 3 Canon PowerShot SD1200 IS Motherboard: Schritt 2, Bild 3 von 3
    • Remove the two screws from the side of the camera casing with the strap. (4mm Phillips 00)
    • Remove the two screws from the bottom of the camera. (4mm Phillips 00)
    • Remove the two screws from the right side of the camera opposite the strap. (2mm Phillips 00)
  3. Canon PowerShot SD1200 IS Motherboard: Schritt 3, Bild 1 von 2 Canon PowerShot SD1200 IS Motherboard: Schritt 3, Bild 2 von 2
    • Pull off the front cover.
    • If the top of the cover sticks, use gentle downward pressure on the retention clips above the lens to release.
    • Remove the back cover.
  4. Canon PowerShot SD1200 IS Motherboard, Motherboard: Schritt 4, Bild 1 von 1
    • Remove the microphone connector by gripping it with the tool and gently, with a wiggling motion, pull it out.
    • Pull the connector straight out by the white connector. Pulling on the wires will damage them.
  5. Canon PowerShot SD1200 IS Motherboard: Schritt 5, Bild 1 von 1
    • Lift off the mechanical shutter button assembly.
  6. Canon PowerShot SD1200 IS Motherboard: Schritt 6, Bild 1 von 2 Canon PowerShot SD1200 IS Motherboard: Schritt 6, Bild 2 von 2
    • Use the spudger to lift the tab on the Zero Insertion Force (ZIF) connector located at the bottom of the motherboard.
    • Be sure you are prying up on the hinged retaining flap, not the connector itself.
    • Slide out the ribbon cable.
    • Use the spudger to pry up each side of the Flat-Topped Connectors
  7. Canon PowerShot SD1200 IS Motherboard: Schritt 7, Bild 1 von 1
    • Remove the press fit ribbon cable by prying upward with spudger tool.
    • It is not necessary to remove the Lens or Flash Assemblies to remove the motherboard.
  8. Canon PowerShot SD1200 IS Motherboard: Schritt 8, Bild 1 von 1
    • Remove the bottom right screw from the motherboard. (4mm Phillips 00)
    • Remove top and lower left black screws from the motherboard. (2.5mm Phillips 00)
  9. Canon PowerShot SD1200 IS Motherboard: Schritt 9, Bild 1 von 1
    • Lift out the motherboard.
Abschluss
Jeff Casper
848 Reputation
7 Anleitungen geschrieben
USF Tampa, Team 17-5, Blackwell Fall 2016 Mitglied von USF Tampa, Team 17-5, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G5
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 9
Insgesamt: 400
