Einleitung
This guide will show you how to properly replace a faulty lens on your Canon PowerShot SD1300 IS.
Was du brauchst
Remove the two 2mm J00 screws on the right exterior.
Remove a single 4 mm J00 on the bottom exterior.
Remove a single 3mm J00 on the left exterior.
Remove a single 2mm J00 screw on the left exterior hidden under the A/V Out port.
Once the front shell of the camera is removed the back shell should slide off just the same.
Use one of your plastic opening tools to separate the screen from the main body of your PowerShot.
Remove five of the 3mm J00 screws under the screen to release the lens for replacement.
Lens assembly should be removed through the front of the camera once screws are removed.
2 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
I have a SD1300 IS and it has another case screw beneath a plastic cover just below the USB port.
Also step 4 shows 2 screws to remove on the lens that do not go through the metal frame. These should not be removed for lens removal.
It is necessary on mine to remove the 2 screws on the left side of the metal frame that attach to the lens assy.
