Einleitung
Screens can be cracked and broken or stop working completely. This guide will show how to replace the screen in the device.
Was du brauchst
Remove the 2.0 mm Phillips screws on both sides of the camera using the Phillips #00 screwdriver.
Remove the 3.0 mm Phillips silver screw from the rear face of the camera, located on the upper right corner.
Using the plastic spudger, pry the golden film on the front face of the camera off of the microchip.
Once removed, a silver screw will be visible from underneath the golden film.
Using the metal spudger, carefully pry the small black tab away from the brown film end of the golden film.
Once released, the small black tab will point straight away from the front face of the camera.
After releasing the tab, the golden film will no longer be secured to the front face of the camera.
Unplug the small chip from the face of the camera by carefully inserting the metal spudger underneath the cluster of red wires visible. Then lift the cluster of wires upwards, parallel to the front face of the camera.
You can now remove the top panel from the camera using your hands with firm pressure.
Insert the metal spudger underneath the golden film on the front face
Lift the golden film on the front face of the camera up and away from its connection
Remove the screen by sliding the golden film out of the channel and pulling the screen away from the camera.
4 weitere Personen haben diese Anleitung absolviert.
