Einleitung
The Canon PowerShot SD200 has an opening for a SD Memory Card. Removing the memory card might be necessary to obtain pictures from the camera. This guide will show how to easily remove the memory card.
Use your fingernail to slide the dark gray tab towards the edge of the camera.
Slide the light gray door away from the LCD screen and pull up to open the door.
Press down on the memory card.
Memory card should pop out of place.
Pull the memory card straight out of the slot.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
