Zum Hauptinhalt wechseln
Canon PowerShot SD30 Control Panel Replacement
Was du brauchst
  1. Canon PowerShot SD30 Control Panel Replacement, Front Cover: Schritt 1, Bild 1 von 2 Canon PowerShot SD30 Control Panel Replacement, Front Cover: Schritt 1, Bild 2 von 2
    • Be sure to remove the wrist strap and battery before removing the cover.
    • Remove the two 2mm black screws that are located on the underside of the camera.
    • Remove the two 3mm silver screws from the right side of camera.
  2. Canon PowerShot SD30 Control Panel Replacement: Schritt 2, Bild 1 von 1
    • Gently remove the front cover.
  3. Canon PowerShot SD30 Control Panel Replacement, Back Cover: Schritt 3, Bild 1 von 3 Canon PowerShot SD30 Control Panel Replacement, Back Cover: Schritt 3, Bild 2 von 3 Canon PowerShot SD30 Control Panel Replacement, Back Cover: Schritt 3, Bild 3 von 3
    • Remove the wrist strap and battery before removing the back cover.
    • Remove the 2mm screw from the back of the camera.
    • Remove two 2mm screws from the bottom of the camera.
    • Remove two 2mm screws the left side of camera.
  4. Canon PowerShot SD30 Control Panel Replacement: Schritt 4, Bild 1 von 1
    • Gently remove the back cover.
  5. Canon PowerShot SD30 Control Panel Replacement, Control Panel: Schritt 5, Bild 1 von 3 Canon PowerShot SD30 Control Panel Replacement, Control Panel: Schritt 5, Bild 2 von 3 Canon PowerShot SD30 Control Panel Replacement, Control Panel: Schritt 5, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use the tweezers to pull up on the piece of black plastic connected to the ribbon to unhook and remove the ribbon connected to the screen.
    • You also have to pull up on the top part of the control panel because it is connected to the metal by a sticky pad.
  6. Canon PowerShot SD30 Control Panel Replacement: Schritt 6, Bild 1 von 3 Canon PowerShot SD30 Control Panel Replacement: Schritt 6, Bild 2 von 3 Canon PowerShot SD30 Control Panel Replacement: Schritt 6, Bild 3 von 3
    • Turn the camera over to the side with the lens and remove the ribbon on the left side.
    • After removing the ribbon there will be a second ribbon to remove that was hiding underneath the first ribbon.
  7. Canon PowerShot SD30 Control Panel Replacement: Schritt 7, Bild 1 von 1
    • Lift up the button that connects to the power button of the camera so you can remove the control panel.
  8. Canon PowerShot SD30 Control Panel Replacement: Schritt 8, Bild 1 von 1
    • Remove the control panel from the camera.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 238
