Einleitung
Follow the steps in this guide to remove and replace the motherboard of the camera. Damage to the motherboard will cause other components to fail.
Was du brauchst
Remove the 2mm screw from the back of the camera.
Remove two 2mm screws from the bottom of the camera.
Remove two 2mm screws the left side of camera.
Remove the two 2mm black screws that are located on the underside of the camera.
Remove the two 3mm silver screws from the right side of camera.
Unscrew the 3mm silver screw from the top of the camera.
Gently remove the top button panel.
Using the tweezers, carefully lift up the 2 folds where the ribbon connects to the motherboard.
Now, lift up the three remaining ribbon connectors to disconnect them.
Gently pull the left wire out and disconnect it from the device.
Use the tweezers to pop the right set of wires out of the connector. Do this by positioning the tweezers under the connector and lifting up.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
