Einleitung
Is your camera not displaying your photos correctly or is the screen not showing any images? Consider using this guide to replace the screen of your camera.
Was du brauchst
Remove the two 2mm black screws that are located on the underside of the camera.
Remove the two 3mm silver screws from the right side of camera.
Remove the 2mm screw from the back of the camera.
Remove two 2mm screws from the bottom of the camera.
Remove two 2mm screws the left side of camera.
Remove top button panel by removing the screw located at the top right of the panel.
Use tweezers to lift the tab that secures the screen wire and remove.
2 weitere Personen haben diese Anleitung absolviert.
