Zum Hauptinhalt wechseln
Canon PowerShot SD30 Screen Replacement
Was du brauchst
  1. Canon PowerShot SD30 Screen Replacement, Front Cover: Schritt 1, Bild 1 von 2 Canon PowerShot SD30 Screen Replacement, Front Cover: Schritt 1, Bild 2 von 2
    • Be sure to remove the wrist strap and battery before removing the cover.
    • Remove the two 2mm black screws that are located on the underside of the camera.
    • Remove the two 3mm silver screws from the right side of camera.
  2. Canon PowerShot SD30 Screen Replacement: Schritt 2, Bild 1 von 1
    • Gently remove the front cover.
  3. Canon PowerShot SD30 Screen Replacement, Back Cover: Schritt 3, Bild 1 von 3 Canon PowerShot SD30 Screen Replacement, Back Cover: Schritt 3, Bild 2 von 3 Canon PowerShot SD30 Screen Replacement, Back Cover: Schritt 3, Bild 3 von 3
    • Remove the wrist strap and battery before removing the back cover.
    • Remove the 2mm screw from the back of the camera.
    • Remove two 2mm screws from the bottom of the camera.
    • Remove two 2mm screws the left side of camera.
  4. Canon PowerShot SD30 Screen Replacement: Schritt 4, Bild 1 von 1
    • Gently remove the back cover.
  5. Canon PowerShot SD30 Screen Replacement, Screen: Schritt 5, Bild 1 von 2 Canon PowerShot SD30 Screen Replacement, Screen: Schritt 5, Bild 2 von 2
    • Remove top button panel by removing the screw located at the top right of the panel.
  6. Canon PowerShot SD30 Screen Replacement: Schritt 6, Bild 1 von 2 Canon PowerShot SD30 Screen Replacement: Schritt 6, Bild 2 von 2
    • Remove screws both at the top and the base of the screen to free the screen.
  7. Canon PowerShot SD30 Screen Replacement: Schritt 7, Bild 1 von 3 Canon PowerShot SD30 Screen Replacement: Schritt 7, Bild 2 von 3 Canon PowerShot SD30 Screen Replacement: Schritt 7, Bild 3 von 3
    • Use tweezers to lift the tab that secures the screen wire and remove.
    • You need to do this for both wires.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 134
