Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
The outer case of the PowerShot SD500 Digital ELPH camera is the part that takes the greatest beating. Every time the camera falls, it lands on its case. Some common problems include cracking and paint wear.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Slide open the battery cover.
    • Slide open the battery cover.
    • Push the small orange tab to the side so the battery can be removed.
  2. Slide the battery out of the battery compartment. Slide the battery out of the battery compartment.
    • Slide the battery out of the battery compartment.
  3. Two Phillips screws need to be removed  using a #00 Phillips screwdriver. The upper screw is under the USB port cover, which can simply be pulled away gently from the casing.  the lower screw is visible on the panel. The screws are different sizes. The .125 inch screw is located under the USB port cover. The 0.85 inch screw goes in the lower hole on the panel.
    • Two Phillips screws need to be removed using a #00 Phillips screwdriver. The upper screw is under the USB port cover, which can simply be pulled away gently from the casing. the lower screw is visible on the panel.
    • The screws are different sizes. The .125 inch screw is located under the USB port cover. The 0.85 inch screw goes in the lower hole on the panel.
    • When looking at the back of the camera, these two screws are on the right panel of the camera.
  4. Essential Electronics Toolkit
    Kompakte Alleskönner.
    Shop Toolkits
    Essential
    Electronics
    Toolkit
    Shop Toolkits
  5. Remove the right side cover from the camera casing.
    • Remove the right side cover from the camera casing.
  6. Remove a .07 inch Phillips screw using a #00 Phillips screwdriver.
    • Remove a .07 inch Phillips screw using a #00 Phillips screwdriver.
  7. Remove two .085 inch Phillips screws from the left side of the camera using a #00 Philips screwdriver.
    • Remove two .085 inch Phillips screws from the left side of the camera using a #00 Philips screwdriver.
  8. Remove the left side cover from the camera.
    • Remove the left side cover from the camera.
  9. Remove three .15 inch Phillips screws from the bottom of the camera using a #00 Phillips screwdriver.
    • Remove three .15 inch Phillips screws from the bottom of the camera using a #00 Phillips screwdriver.
  10. Once the casing is unscrewed, hold the camera with one side facing down, and lift the opposite face of the casing to open it. Remove the internal camera components and layout out all pieces on a clean surface.
    • Once the casing is unscrewed, hold the camera with one side facing down, and lift the opposite face of the casing to open it.
    • Remove the internal camera components and layout out all pieces on a clean surface.
    • The front and back cover may require gentle rocking to remove.
Abschluss
Taylor Shields
831 Reputation
8 Anleitungen geschrieben
Clemson, Team 2-1, Benson Fall 2014 Mitglied von Clemson, Team 2-1, Benson Fall 2014
CLEM-BENSON-F14S2G1
4 Mitglieder
9 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 114
